Provider (P) Router in IP MPLS Network
abdul.qadir5001
Can we design a MPLS network without a Provider (P) router. If there is no Provider (P) router then how labels swapping will be performed?
Yes you will have labeling swapping, remember the PE and P have the same configuration about MPLS basically but PE has MPBGP and the client routing protocol as well, you will be using OSPF or IS-IS internally and it will enable the exchange of labels, I have created a mini lab with 3 routers:
R4(CLIENT) ---- R2(PE) ---- R1(PE) ---- R3(PE)  (no full mesh)
R1#show mpls forwarding-table
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
16 Pop Label 2.2.2.2/32 638 Et0/0 10.0.0.2
17 Pop Label 3.3.3.3/32 756 Et0/1 20.0.0.3
R1#
R2#show mpls forwarding-table
200 No Label 3.3.3.3/32[V] 0 Et0/1 192.168.1.2
201 No Label 192.168.1.0/24[V] \
0 aggregate/CLIENTE
202 Pop Label 1.1.1.1/32 0 Et0/0 10.0.0.1
203 Pop Label 20.0.0.0/24 0 Et0/0 10.0.0.1
204 17 3.3.3.3/32 0 Et0/0 10.0.0.1
R2#
R3#show mpls forwarding-table
300 Pop Label 1.1.1.1/32 0 Et0/0 20.0.0.1
301 16 2.2.2.2/32 0 Et0/0 20.0.0.1
302 Pop Label 10.0.0.0/30 0 Et0/0 20.0.0.1
R3#
R3#SHOW IP ROUTE VRF CLIENTE
Routing Table: CLIENTE
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
4.0.0.0/32 is subnetted, 1 subnets
B 4.4.4.4 [200/11] via 2.2.2.2, 00:00:02
B 192.168.1.0/24 [200/0] via 2.2.2.2, 00:00:58
R3#
You can see the forwarding table of each one.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
5 Replies 5
Julio E. Moisa
Yes you can, but all the routers should work as PE, it will be seen in a small lab mostly, connecting PE with PE and using OSPF internally for example but it is not scalable and suggested, in the most of the case the ISP´s MPLS networks are huge and the P routers are part of their core network. By design a MPLS network without P routers should not be a good practice taking in consideration many factors, security, cpu utilization, scalability, resources, etc.
Regards.
So if there will be no Provider (P) router so no labeling swapping will be? Only we have label push and pop process in MPLS Network?
R1#
0 aggregate/CLIENTE
R2#
R3#
R3#
Dear Julio E.Moisa Thank you very much for such a great explanation
Thank you Abdul, it was a pleasure, have a great weekend.
