Public IP address behind router
mursel2010
Hi there,
I'm really bad on networking so I have a question about NAT.
I got two public IP addresses from my ISP: 92.x.x.252 - 92.x.x.254.
92.x.x.254 is configured as secondary on external interface and clients will use it two connect (vpn) it from outside through cisco 1841 to zywall p1 with wan ip address 92.x.x.253. Is this configuration (look at picture) allowed? How can I route traffic from 92.x.x.254 to zywall p1, if posible?
Thanks in advance!
http://i41.tinypic.com/24e2r2r.png
fb_webuser
Level 6
Level 6
For my opinion you have to make static mapping:
ip nat inside source static IP( zywall p1) 92.x.x.254
Also you need:
Interface to modem# ip nat outside
Interface to switch# ip nat inside
You will get: that all traffic wich destined for 92.x.x.254
will go to zywall p1
Posted by WebUser Aleksandr Yanovskiy
10 Replies 10
fb_webuser
Level 6
Level 6
Also you need:
Thanks for help... anyway still can't ping zywall on 92.x.x.253 address. More info:
cisco#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.0.1.10                  7   0010.b5d8.f828  ARPA   FastEthernet0/0
Internet  10.0.1.1                    -   001c.5849.9024  ARPA   FastEthernet0/0
Internet  80.x.x.1                  16   0030.8550.58af  ARPA   FastEthernet0/1
Internet  92.x.x.254                -   001c.5849.9025  ARPA   FastEthernet0/1
Internet  92.x.x.253                0   Incomplete      ARPA
Internet  80.65.83.48             -   001c.5849.3025  ARPA   FastEthernet0/1
and this:
007071: *Mar  9 23:32:30.578 CST: IP ARP req filtered src 92.x.x.253 0013.491e.77cb, dst 92.x.x.254 0000.0000.0000 wrong cable, interface FastEthernet0/0
007072: *Mar  9 23:32:30.754 CST: IP ARP: sent req src 92.x.x.254 001c.5889.9025,
                 dst 92.x.x.253 0000.0000.0000 FastEthernet0/1
007073: *Mar  9 23:32:30.754 CST: IP ARP: sent req src 92.36.231.254 0,
                 dst 92.x.x.253 0 FastEthernet0/1
fb_webuser
Level 6
Level 6
What is the gateway for zywall p1? Can it ping devices outside you office? Gateway must be set to 92.x.x.254. Try this
Sorry but I'm not following you. 92.x.x.254 is wan interface on cisco (secondary ip address) and 92.x.x.253 is wan interface on zywall p1 (image in first post).
Uh oh... it was late night here sorry... you said gateway for zywall p1 and i refered to external interface ip address. I'll check this out. thnks!
Gateway on p1 is set to 92.x.x.254... i can't even ping this py from outside.
Here's my config:
Current configuration : 3518 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
no aaa new-model
resource policy
clock timezone CST -1
clock summer-time CDT recurring
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip dhcp use vrf connected
no ip bootp server
ip domain name mikroaldi.org
ip name-server 195.x.x.10
ip name-server 195.x.x.20
description LAN
ip address 10.0.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description WAN
ip address 92.x.x.254 255.255.255.252 secondary
ip address 80.x.x.48 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface Serial0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 80.x.x.1
no ip http server
ip nat inside source list 101 interface FastEthernet0/1 overload
ip nat inside source static tcp 10.0.1.10 80 80.x.x.48 80 extendable
ip nat inside source static 92.x.x.253 92.x.x.254
logging trap debugging
access-list 101 permit ip any any
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
line aux 0
line vty 0 4
scheduler allocate 4000 1000
end
Any clue?
fb_webuser
Level 6
Level 6
Did your provider give you such IP addr:
They are quite diffren.
Anyway, It seems that we are talking on different areas)
As I understand you want to make zywal accessible from internet with address 92.x.x.253. So you should assign this addr to wan interface of you router, and then set a static nat.
Am i right?
My primary IP address is 80.x.x.48 and after a while i needed 2 more addresses so they gave me these 92.x.x.252 / 30.
And yes.. I want to make zywall accessible from internet by using one of these 92.x.x.252. In this case 92.x.x.253.
fb_webuser
Level 6
Level 6
In this case you can try 2 scenrios:
1) Static nat. In this case you have to assign addr *.253 to your router with WAN interface. And then you can use static NAT
2) Oter decision is to assign *.253 to you zywall p1. In this case you have to assign internal adress to interface on the picture, where you have now *.253 and *.253 addr assign to loopback addr. or subinterface. And then add route on you router
ip route *253 255.255.255.255 $Internal IP.
Choose one of variants and then let's continue) You can write directly to my facebook, it would be quicker Aleksandr Yanovskiy
fb_webuser
Level 6
Level 6
Lets say I want to use first scenario... i can set 92.x.x.253 as a secondary ip address on wan interface of 1841, but what about wan interface of zywall? it will use same ip address as my wan interface on router? As of second option i'm not sure i can configure that. And one more thing this zywall is another agency device. Its not of our company.
Posted by WebUser Mursel Musabasic
