Public ip on 2 different routers
pcromwell
Level 3
Level 3
I have 2 routers joined together by their 0/1 Lan interfaces.
Router A   0/0 Lan interface is hosting the public ip of  say 178.0.0.0  255.255.255.248
Router B is connected to Router A via the 0/1 as previously stated.  I would like to add 178.0.0.1 to Rotuer B 0/1 interface.
Is their a way I can do it without having to chop up my subnet?
In case you were wondering why. I need to setup a test router ( Router B) for some VPN development, and I don't want to interfere with the live Router A
does anyone ahve any ideas?
amabdelh
The two routers have to be in the same segment, otherwise you will have connectivity issues with routing packet from and to the internet
