Public IP's Behind Static IP
Frosty3222
Hello, I have a 827 router with a assigned static ip of xxx.xxx.xxx.142 255.255.255.0 as well as a block of public IP's which have a net mask of 255.255.255.248 . I would like all the hosts with the block of public ip's to be visible to the internet. I don't wish to use DHCP or NAT/PAT, just straight routing. Thanks.
Hi there,
I can see that the NAT configuration is still there, kindly remove the "ip nat outside" from the dialer interface, and "ip nat inside" from the LAN interface (ethernet0), using "no ip nat outside" and "no ip nat inside" on the respective interface.
HTH, please rate if helpful,
Mohammed Mahmoud.
26 Replies 26
royalblues
Level 10
Level 10
Need more information.
IS this router your border router conencted to the ISP?
Are the hosts with the public IP block directly connected to the border router?
Is the IP block assigned by the service provider or your own?
A brief topology would help to provide a suitable solution
Narayan
Yes the router is connected to the ISP. Yes the IP block has been assigned by the service provider. The hosts are connected to a 2924 switch then to the router. They are in a VLAN on the switch. When attempting to connect to one of the hosts from a separate ISP the packets make it as far as the static ip of the WAN on the router. Hope this helps.
Thanks.
Hi there,
If i understand well your scenario should look like this:
hosts -> 2924 Switch --> 827 router --> Internet
To do it routing all the way with no NAT --> You'll need 2 public IP subnets, 1 for LAN and 1 for WAN, and your ISP shall route your LAN IPs to your WAN ips and you should use default route towards your provider, then you should configure the public IPs on your hosts manually, but here comes the most important question, how many hosts do u have (and accordingly the LAN subnet that you need).
HTH,
Mohammed Mahmoud.
What is the gateway of the ip hosts. Is it the static ip address of the WAN router?
hosts-->switch--->router--->ISP
If the topology looks something like the above, then make sure you have a default route configured on your edge router.
HTH,
Narayan
I have six usable ips for my LAN with a subnet of 255.255.255.248 I have assigned one of those ips to the LAN side of my router. I have also manually configured the ips of the hosts with default gateway listed as the ip of the LAN port of the router. Your topology of my network is correct. Is the problem the different subnets of the LAN vs WAN ie. x.248 x.255 ?
Friend,
Your Gateway IP should have the same Subnet mask as that of the configured hosts.
Change the LAN IP of the router to x.x.x.142 255.255.255.248 and confgiure the default route to the ISP
HTH, rate if it does
Narayan
Did you mean change the WAN netmask to 255.255.255.248 ? The LAN netmask is already 255.255.255.248 And by default route to the ISP do you mean the IP of the next hop after my router ?
Hi there,
No the subnet mask of the LAN and the WAN should not match, what are the LAN and WAN subnets you acquired from your ISP ?
regards,
Mohammed Mahmoud.
The LAN subnet is 255.255.255.248 The WAN subnet is 255.255.255.0
Hi there,
Weird, the WAN is /24, are both LAN ips and WAN ips public ips ?
regards,
Mohammed Mahmoud.
Let me give an example
host-->switch-->(lan)router(wan)-->ISP
Host: - 10.10.10.2/29
router LAN:-10.10.10.1/29
router WAN:-20.20.20.2/30
ISP WAN:- 20.20.20.1/30
your host should have a gateway configured as 10.10.10.1
How many VLANs have been configured on the switch and the public hosts belong to which VLAN?
Naayan
Are multiple VLANS configured on the switch?
if yes then i think i understand your problem
You have to create a trunk connection from the router to the switch with subinterfaces
Narayan
I eliminated the switch and connected the server directly to the router. Still unable to connect with the server on the LAN side from another ISP. Or able to ping out beyond the LAN interface.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip name-server xxx.xxx.xxx.xxx
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
partition flash 2 6 2
interface Ethernet0
ip address xxx.xxx.xxx.xxx 255.255.255.248
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface Dialer1
ip address yyy.yyy.yyy.yyy 255.255.255.0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxxxxxxxxxxx
ppp chap password yyyyyyyyyyyyyyyyyyyy
ppp pap sent-username xxxxxx password yyyyyyy
ip nat inside source list 102 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http access-class 23
access-list 23 permit xxx.xxx.xxx.0 0.0.0.7
access-list 102 permit ip xxx.xxx.xxx.0 0.0.0.7 any
dialer-list 1 protocol ip permit
line con 0
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 120 0
login
length 0
scheduler max-task-time 5000
end
Hi there,
Can you ping from the router to the internet ?
/24 public ip on WAN is a weired thing, are you sure its a public ip ?
regards,
Mohammed.
