Public IP's Behind Static IP
Frosty3222
Hello, I have a 827 router with a assigned static ip of xxx.xxx.xxx.142 255.255.255.0 as well as a block of public IP's which have a net mask of 255.255.255.248 . I would like all the hosts with the block of public ip's to be visible to the internet. I don't wish to use DHCP or NAT/PAT, just straight routing. Thanks.
26 Replies 26
Hello, thanks to a quick fix to a faulty NIC, I can now access the internet from the server as well as access the server from another host on the same LAN/Netmask. I however cannot access the server from another ISP on the WAN side. I also went over the firewall on the server. It doesn't seem to be a issue. I double checked the netmask for the static WAN, it is what the ISP gave me.
Hi there,
This /24 WAN IPs is still a weired thing, anyway u can't reach the server from another provider because of the NAT configuration, try access "http://whatsmyip.org/" from your server to see th ip address that your server goes to the outside world with (it should be your WAN ip not the manually configured server ip).
HTH,
Mohammed Mahmoud.
Yes the IP address did come up with the WAN ip. How do I configure it so that the server is reachable with its own public IP ? And also any other servers behind the router with their own public ips ?
Hi there,
I am glade that we are reaching somewhere. In order to make it reachable to the internet with its public ip address you'll have to:
Remove the NAT configuration.
Make sure that your ISP has routed your LAN IPs to your WAN IPs or to your router.
Use default route at your router.
HTH, please rate if helpful,
Mohammed Mahmoud.
NAT configuration is removed. (See post config above)
ISP has routed Block of public IPs to static WAN. If I do a trace route to the public IP of the server it stops at the WAN side of the router with the LAN side unreachable. I am not sure what you mean by default route at the router ?
Hi there,
If the servers on the LAN are unreachable from the internet:
Check connectivity problems between the server and the router, simply ping the router from the server.
Check the default gateway on the server (must be the IP address of the router's LAN interface facing the server)
Check that the router has a default route pointing either to the outgoing interface connecting to the internet, or to the next-hop ip address which is the ip address of the first hop (router) facing you in your ISP.
HTH,
Mohammed Mahmoud.
No connectivity issues between the server and router. Ping successful. Server default gateway is the LAN interface on the router. Please see posted config for possible errors. This is the only router. i.e. the WAN interface is facing the ISP.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip name-server xxx.xxx.xxx.xxx
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
partition flash 2 6 2
interface Ethernet0
ip address xxx.xxx.xxx.xxx 255.255.255.248
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface Dialer1
ip address yyy.yyy.yyy.yyy 255.255.255.0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxxxxxxxxxxx
ppp chap password yyyyyyyyyyyyyyyyyyyy
ppp pap sent-username xxxxxx password yyyyyyy
ip nat inside source list 102 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http access-class 23
access-list 23 permit xxx.xxx.xxx.0 0.0.0.7
access-list 102 permit ip xxx.xxx.xxx.0 0.0.0.7 any
dialer-list 1 protocol ip permit
line con 0
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 120 0
login
length 0
scheduler max-task-time 5000
end
Hi Frosty.
By default route we mean this part of your router configuration.
I don't get your wan connection. This is a ADSL connection ? Ip address of your router is dynamically assigned by your ISP. This interface, Dialer1 is the interface that gets the ip address of wan connection ?
Anyway, you can do a test pinging any other address on internet using the ip address of your ethernet interface.
The command is:
ping x.x.x.x source ethernet 0
or if you IOS dont't supoort this commmand
ping ip
Target IP address: x.x.x.x
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: Ethernet0
With this you can exclude your lan network connectivity.
Hope helpfully.
Best Regards.
It is a 827 router with a ADSL connection.
The WAN IP address is static.
I have a block of 6 public IP's on the LAN side I wish to make accessible from the internet. One of those IP's is assigned to the LAN port. I can access the internet from the server on the LAN, but I can not access the server from the internet. If I traceroute to the server's IP from a separate ISP it stops at the WAN side of the router.
Hi there,
I can see that the NAT configuration is still there, kindly remove the "ip nat outside" from the dialer interface, and "ip nat inside" from the LAN interface (ethernet0), using "no ip nat outside" and "no ip nat inside" on the respective interface.
Mohammed Mahmoud.
That solved the problem.
Thank you very much for your help.
Hi John,
You are more than welcomed.
best regards,
Mohammed Mahmoud.
