Public network behind BGP on VLAN
radupavloff
I have an issue. I can't connect to any of the IP 193.104.x.x/24 from outside my network.
WAN INTERFACE:
interface GigabitEthernet8
 description Link-GTS
 ip address 85.9.x.x 255.255.255.252 secondary
 ip address 193.226.x.x 255.255.255.248
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nbar protocol-discovery
 ip flow ingress
 ip nat outside
 ip virtual-reassembly in
 ip verify unicast reverse-path
 duplex auto
 speed auto
LAN INTERFACE:
interface Vlan1
 ip address 193.104.x.x 255.255.255.0 secondary
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
ip nat inside source list NET_GTS_ACL interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 193.226.x.x track 1
ip route 0.0.0.0 0.0.0.0 89.18.x.x 10
ip access-list standard NET_GTS_ACL
 remark CCP_ACL Category=18
 permit 193.104.5.0 0.0.0.255
 permit 192.168.1.0 0.0.0.255
 permit 192.168.10.0 0.0.0.255
Francesco Molino
I'm not sure I get your concern.
You want from outside to reach your secondary IP on vlan1 right?
Why are you natting this public network to your WAN interface?
From outside does this 193.104.x.x networks is known? I mean, from extern host, do they know to go through your 193.226.x.x network to reach 193.104.x.x subnet? Or are you advertising this network over BGP?
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
I'm advertising through bgp.
router bgp AS
 bgp log-neighbor-changes
 network 193.104.x.0
 neighbor 85.9.x.x remote-as 5588
 neighbor 85.9.x.x description gts
 neighbor 85.9.x.x next-hop-self
 neighbor 85.9.x.x send-community
 neighbor 85.9.x.x soft-reconfiguration inbound
If you're advertising this network, as it is a public IP you should be able to reach it.
However I'm sorry but I didn't get you why you're natting this subnet.
When you're saying that you can't access it, how do you test it and do you see packets arriving on that router from external hosts?
PS: Please don't forget to rate and mark as correct answer if this solved your issue
Francesco
I had NAT for that subnet on another backup interface. Thanks!
