Putty issue
Anukalp S
Hi i have been observing a issue, i am taking console access of  cisco ios switch. When ececuting sh run command it generated few output and break. It dont prompt for more option to see rest outputs. I tried with term len 0 but it shows all outputs in one go. When i do term no len to set length default, i dont find more option, Could someone help what could be issue here.
Giuseppe Larosa
Hello @Anukalp S ,
every character should be fine to work as a more in the output of Putty I think I used to press the space bar to achieve this.
Hope to help
Giuseppe
Hi Giuseppe, there is no more option so i can use space bar. When executing sh run, the output shows few config and terminal shows switch#, if i use term len 0 then i shows full config but in one shot
Martin L
I think default settings are 24 lines, so do term length 24 to go back from term length 0
