PVC on ATM
jmolefe
Hi there,
I have 3620 router which can handle 1024 vc's ( ATM OC3) I want to replace it with cisco 7206VXR ( ATM WAN OC3+) which can cater for 8191 vc's. The problem is that the the vc's comes up on the new router ( 7206) but IP connectivity through atm doesn't work. Any idea ?
mheusinger
Level 10
Level 10
can you post the config of one of the PVCs as well as the ATM interface and IP routing config?
There can be many reasons for no IP connectivity ...
Regards, Martin
