How to prefere RIP advertisement over BGP?
amaliasch
Router A connected to Router B running RIP
Router C connected to Router D running RIP
Routers B and D running BGP.
Router B learn a prefix from Router A, and Router D learn the same prefix from Router C.
because Router B learns the same prefix from D by BGP, it prefered the BGP routes because of the Admin' distance.
I would like Router B to prefred the routes learned from A by RIP.
How to do it?
mheusinger
Level 10
Level 10
you can configure the administrative distance of BGP through:
distance bgp
Example: distance bgp 200 200 200
Hope this helps! Please rate all posts.
Regards, Martin
attrgautam
Level 5
Level 5
You can probably implement BGP backdoor links.
On router B, configure the network as
network 10.0.0.0 backdoor.
