PVDM4-128 on Router Motherboard vs Install in T1/E1 Card
johnlloyd_13
Level 9
Level 9
hi,
i'm going to prepare and configure a voice 4k ISR router. this is to replace an old 29xx router.
just wondering what's the best approach/practice for installing a PVDM4-128 card: install directly on the router motherboard or install in the T1/E1 NM card?
the old 29xx router currently has an ISDN line connected.
also just considering if in case router will move to SIP and disco the ISDN. was thinking the PVDM-128 might be removed by another engineer if he want to use the NM slot i.e. a switch module or extra gig ports.
marce1000
                                                Looks like both may apply
 - Following : https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet_c78-728307.html , ref Table 1 :
PVDM4-128(=)
On-board motherboard or T1/E1 module slot
128-channel high-density voice DSP module, or spare
