Q count EIGRP non zerp
spinning2008
Hello I have an EIGRP with 10 neighbors but the Q cout is not zero is in 200. This is normal?. The cpu process is normal and memory too.
Thanks.
Mauro
2 Accepted Solutions
Q count is zero what is  equal to 200 is RTO in msec. So far everything looks ok.
Regards.
Alain.
Hi Mauro ,
Alain is right , the Q is 0.
Take it from the end to start  : Seq , Q , RTO
On each row, the last number is the sequence ( the big number) , the q , then RTO.
Dan
6 Replies 6
cadet alain
No this is not normal. You surely have a L2 problem like unidirectional link or an ACL blocking EIGRP packets.
Can you post sh ip ei nei output.
Regards.
Alain.
Thanks for answer:
this is the show ip eigrp neighbors:
SW/#show ip eigrp neighbors
IP-EIGRP neighbors for process 1
H   Address                 Interface   Hold Uptime   SRTT   RTO  Q  Seq Type
                                        (sec)         (ms)       Cnt Num
7   192.168.255.13          Vl400             14 2w2d            20   200  0  8188067
4   192.168.255.23          Vl400             14 2w2d            20   200  0  8188535
6   192.168.255.31          Vl400             14 3w6d            25   200  0  2095514
0   192.168.255.1           Vl400             14 3w6d            11   200  0  107399045
8   192.168.255.5           Vl400             14 5w1d            10   200  0  144717
5   192.168.255.32          Vl400             14 22w5d          50   300  0  3047946
3   192.168.255.2           Vl400             14 22w5d          18   200  0  11361322
2   192.168.255.11          Vl400             14 22w5d         17   200  0  12384301
1   192.168.255.4           Vl400             14 22w5d         12   200  0  1520360
SW_SVC100R0-2/SAGRERA#
I can't see any SRTT, this is  switch 3550
Mauro.
Regards.
Alain.
Hi Alain, no the seq number is 0,  the Q Count is 200.
Mauro
Hi Mauro ,
Dan
Yes is truth. Thanks I'm blind.
Thanks for all.
Mauro
