QOS bandwidth sharing
Tony JOrdan
Hi folks,
can anyone advise of this kind of scenario where we have 2 separate networks (sites) connected to the same router providing access to the same core.
Network A (netA) & Network B (NetB) .
Quite simple network A & B would have 60% and 40% bandwith respectively.
Now the question is if either network wanted to use more bandwidth than its allocation if the there was availability would this be possible, and to how to configure?
Cheers
Dash
Hello
Do you mean two internal networks using one router to access the wan?
If that's the case then one way would to mark your network traffic as it enters the router from the LAN interfaces via class map + acls etc and then apply CBWFQ upon this marked traffic on the wan egress interface
If either class isn't utilising its allocate bw this would be shared between all other class by default on the ratio of bw % allocated on the other classes.
Res
Paul
Kind Regards
Paul
Hello
Res
Paul
Kind Regards
Paul
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Could you clarify how your two network/sites connect to the same router?
Normally when you share bandwidth, you're share some common link.
