connected pc unable to get to the internet
alexheng81
Hi All,
I am having issues getting to the internet from the PC. It's currently connected to the cisco 877w via FE0.
The PC is able to grab the correct IP address. Even when I input the dns [8.8.8.8], I am still not able to access the internet.
Attached is the config -
version 12.4
no service pad
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.254
ip dhcp pool HOME-DHCP
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254
   dns-server 8.8.8.8
no ip bootp server
ip name-server 8.8.8.8
ip name-server 165.21.100.88
archive
log config
  hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
ip flow ingress
pvc 0/100
  encapsulation aal5snap
  protocol ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.1.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxx@xxx password 7 130D44185206173829
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
John Blakley
Can you ping 8.8.8.8 from your router? If so, all you'll need is to configure nat on the router:
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 100 interf dialer0 overload
int vlan 1
ip nat inside
int dial0
ip nat outside
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
5 Replies 5
John Blakley
int vlan 1
ip nat inside
int dial0
ip nat outside
HTH,
John
Thanks so much for the help! All is working fine now. So it's all about the ACLs that is causing the issue. cheers.
One more question - can someone please teach me how to configure the wireless module of this 877w?
JohnTylerPearce
Level 7
Level 7
Can you souce a ping from your vlan1 interface to 8.8.8.8?
For Example: ping 8.8.8.8 source 192.168.1.254
Also can you post the results of a traceroute to 8.8.8.8 from this PC?
And my last question, is your Internet Service currently up?
@John - thanks but I got it all sorted out.
cheers
If you can assist with the wireless, it would be very much appreciated!
Can you start a new post about your wireless issue?
Thanks!
John
