QOS Basic Setup
Jesse Hottle
Level 4
Level 4
I need a basic configuration for QOS that will prioritize all VOIP, WEB, FTP, and email traffic. I want all other traffic to be allowed, but I want the traffic above to have priority.
I am new to this, so I am not sure who to setup this policy.
Thanks for any suggestions.
10 Replies 10
network.king
Level 8
Level 8
It would be useful if you have three classes rather than two classes with one prioritised
and other left to default
You can have three classes , one for Voice with priority , other spefified ones in another class with some dedicated bandwidth
and left ones in the default class.
Pls refer this link for basic QOS Config
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800bd909.html#89799
for priority queuing , search for "priority "
Hope this helps
regards
vanesh k
Hieu Cao
Level 7
Level 7
I dont' know what router you're using, but here's the basic config that you can use if your router can support NBAR.
class-map match-all VOIP
match ip dscp ef
class-map match-any Call-Signaling
match ip dscp cs3
class-map match-any Critical-Data
match protocol http
match protocol ftp
match protocol smtp
class-map match-any Network-Control
match ip dscp cs6
class-map match-all Scavenger
match ip dscp cs1
policy-map LAN-QoS
class VOIP
priority percent (% of bandwith you want to allocate)
class Call-Signaling
bandwidth percent 5
class Network-Control
bandwidth percent 5
class Critical-Data
set ip dscp af21
bandwidth percent (% of bandwith you want to allocate)
random-detect dscp-based
class Scavenger
bandwidth percent 1
class class-default
Then apply this policy-map LAN-QoS to your interface:
- service-policy output LAN-QoS.
By default, Cisco only allows 75% of configured bandwidth, so if you want to use 100% of it, you will need to add this command "max-reserved bandwith 100" to the same interface that you're applying the policy-map.
After applying the policy, you can use this command "sh policy-map interface xxx" to monitor packet hits.
HTH,
hieu
pls rate post if it helps.
Thanks for the post. How can I tell if this is actually working? I can see the statistics, but there is not a lot of informative information.
Jesse
Jesse,
What information are you looking for and not seeing?
Please post your router config with the "show policy-map interface xxx results".
hieu
Maybe I need to clarify more. I am trying to prevent users from behind this router from hogging all available bandwidth (normally p2p traffic) and allocating a defined amount ofr bandwidth for http, https, ftp, email, dns, etc..
Also, I am getting ready to change this network to a multiple vlan and router sub-interfaces setup. Right now the current config is for testing.
Thanks, I am very new to this.
Your current QoS is working as you've defined it. When you issue the command "show policy-map int f0/0", you're seeing the packet hits against the class-map that you specified as shown in network, critical-data, and default.
I think what you're not seeing is the packet hits for the "class-map match-any PTP". The reason why you don't see it is because you've 3 different policy-maps specified (qos, block-PTP, and port-limit), but only the "qos" is applied to your f0/0 interface, and the "class PTP" is not listed in the "qos" policy.
What you can do is to move the class PTP
police 8000 1000 1000 conform-action drop exceed-action drop violate-action, under policy-map qos.
Take a look at this link and look for "Enterprise QoS Solution Reference Network Design Guide Version 3.3". It'll give you some good info on QoS.
http://www.cisco.com/en/US/netsol/ns656/networking_solutions_program_category_home.html
HTH,
hieu
I also have a L3 3550 I would like to configure QOS on, but these commands do not work on this switch. Anyway to do this on a 3550 also?
Thanks again.
jesse
On the swith, QoS is configured a little different than in the router.
You enable QoS globally by entering "mls qos" command, then use "mls qos trust dscp/cos" for individual switch port.
or you can use Auto QoS and issue "auto qos voip ciscophone" at the port level.
HTH,
hieu
So this is per port, even if ports are associated to a vlan?
