QoS causing router CPU utilization to rise
Angelo ANELLO
Hi Guys,
     We have recently implemented some QoS on our routers and i have noticed that the CPU usage has risen enormously as a result.  Can someone advise if this is normal?
I checked the CPU Processes and found that the avg values are 50% usage.  This seems rather high considering that only 75% of our edge routers have this feature enabled.
Our main router is a Cisco CISCO2911/K9 (revision 1.0) with 487424K/36864K bytes of memory.  Our edge routers are either 2801 models or 881 models.
This is our first implementation of QoS and would like to ensure that it is working properly before implementing other QoS rules.  Here is a copy of the config on the 2911 router:
class-map match-all Citrix
match protocol citrix
class-map match-all Print
match protocol printer
class-map match-all C-Coolingata
match access-group name Coolingata
class-map match-all C-Hawthorn
match access-group name Hawthorn
class-map match-all C-MonaVale
match access-group name MonaVale
policy-map Shape2M
class Citrix
  priority percent 80
  set dscp af41
class Print
  bandwidth remaining percent 20
  set dscp af11
  random-detect
class class-default
  bandwidth remaining percent 80
  random-detect
policy-map Global
class C-Hawthorn
  shape average 2048000
  service-policy Shape2M
class C-MonaVale
class C-Coolingata
policy-map Shape4M
class Citrix
  priority percent 80
  set dscp af41
class Print
  set dscp af11
  random-detect
class class-default
  random-detect
policy-map Shape1M
class Citrix
  priority percent 80
  set dscp af41
class Print
  set dscp af11
  random-detect
class class-default
  random-detect
ip access-list extended Coolingata
permit ip any 192.168.65.0 0.0.0.255
ip access-list extended Hawthorn
permit ip any 192.168.76.0 0.0.0.255
ip access-list extended MonaVale
permit ip any 192.168.34.0 0.0.0.255
int LAN0
   ip nbar protocol-discovery
int WAN
   service-policy output Global
Here is the config on our edge routers:
class-map match-any Citrix
match access-group name Citrix-ACL
policy-map WAN
class Citrix
  priority percent 80
  set dscp af41
class class-default
  bandwidth remaining percent 100
  random detect OR fair queue (dependant on router type)
policy-map Global
class class-default
  shape average 20480000 (number equal to the link speed)
  service-policy WAN
ip access-list extended Citrix-ACL
permit tcp any 192.168.1.0 0.0.0.255 eq 1494
permit tcp any 192.168.1.0 0.0.0.255 eq 1604
int WAN
As you can see we have different link speeds at different sites based on their size, location etc.
Can anyone see any issues or be able to confirm that this config is correct?
Your help is appreciated
18 Replies 18
What command you suggest instead WRED?
2821 seems EoL so IOS is latest available: c2800nm-advipservicesk9-mz.151-4.M7.bin
Just checked: 22% and 1 Mbps the whole night. IP Input 2%.
NAT with 5000 translations, bunch of Tunnels, NetFlow.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
"What command you suggest instead WRED?"
Per class FQ.
"bunch of tunnels" . . .
How many is a bunch?  Running a dynamic routing protocol over them?  Maybe control plane usage from that?  This might be the type of question you would need to persue with TAC.
Thanks for reminding me about tunnels. Did some RTFM:
http://www.cisco.com/c/en/us/support/docs/quality-of-service-qos/qos-policing/10106-qos-tunnel.html
The qos pre-classify command can be used in order to classify traffic based on values other than IP precedence or DSCP.
You're right (as always). I removed "qos pre-classify" as excessive.
I shape egress traffic from Branch to HQ on physical interface. Traffic going to tunnel was already marked with DSCP and tags are cloned to IPSec packets.
I catch it on HQ side and skip unneeded classification, that preserves some CPU:
class-map match-any Marked
 match protocol ipsec <- should I use "match access group (permit esp any any)"?
 match not  dscp default
policy-map Mark <- WAN&LAN combined input policy
 class Marked
 class Mark_Scavenger
  set dscp cs1
 class Mark_Streaming_Video
  set dscp cs4
Disclaimer
Posting
"You're right (as always)."  Laugh - alas, not always.  If fact, there was the time I thought I made a mistake, but I was mistaken.  ;)
"match protocol ipsec <- should i replace it with match access group (TCP 500)?"
Hard to say.  NBAR is sometimes no more than a pretty face on an ACL, and as such, shouldn't use any more CPU but it's a little clearer in the config what you're matching.  (Somewhat similar where some IOS vesions will substitute service names for port numbers within ACLs, e.g. WWW for 80.)
Some NBAR does examine deeper than a port number, but sometimes that's important to truly identify the traffic you want.
