QoS cisco 1841 - ios won't let me set correct UBR value ?
tonysweeney
Hi, easy one this! (hopefully)
I am trying to set up QoS on a pvc on a 5Mb adsl line :
tranetvpn1(config-subif)#pvc
tranetvpn1(config-subif)#pvc 0/
tranetvpn1(config-subif)#pvc 0/38
tranetvpn1(config-if-atm-vc)#ubr
tranetvpn1(config-if-atm-vc)#ubr ?
<32-832> Peak Cell Rate (PCR) in Kbps
but it will not let me enter above 832 as a peak cell rate - why is this ?
Thanks!
5 Replies 5
tonysweeney
This is the config that I am trying to add QoS onto :
class-map match-all pbx-vosig
match access-group 105
class-map match-all voip-adsl
match access-group 102
class-map match-all vosig-adsl
match access-group 103
class-map match-all pbx-adsl
match access-group 104
policy-map PBX
class pbx-vosig
set ip dscp cs5
class pbx-adsl
set ip dscp ef
class class-default
set ip dscp default
policy-map LLQ
class voip-adsl
set precedence 1
priority percent 70
class vosig-adsl
bandwidth remaining percent 4
set ip dscp default
class class-default
set ip dscp default
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key xxx address xxx
crypto isakmp keepalive 10
crypto ipsec transform-set 3desmd5 esp-3des esp-md5-hmac
crypto ipsec df-bit clear
crypto map tranetvpn 50 ipsec-isakmp
set peer x
set transform-set 3desmd5
match address a1
reverse-route
interface Loopback0
no ip address
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.2 point-to-point
bandwidth 4096
no ip redirects
no ip proxy-arp
no snmp trap link-status
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Vlan1
description ***LAN IP ADDRESS***
ip address 10.0.0.11 255.255.255.0 secondary
ip address 192.168.120.240 255.255.255.0
no ip redirects
no ip proxy-arp
ip virtual-reassembly
ip tcp adjust-mss 1452
service-policy input PBX
interface Dialer0
ip address x 255.255.255.254
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxx
ppp chap password 7 xxx
ppp pap sent-username xxx
24B
ip route 0.0.0.0 0.0.0.0 192.168.120.251
no ip http server
no ip http secure-server
ip access-list extended a1
permit ip 192.168.120.0 0.0.0.255 192.168.121.0 0.0.0.255
permit ip any 192.168.121.0 0.0.0.255
access-list 102 permit udp any any dscp ef
access-list 103 permit tcp any eq 1720 any
access-list 103 permit tcp any any dscp cs5
access-list 105 permit tcp any any eq 1720
ok, think I have worked it out after doing a lot of reading, the upsteam bandwidth is 832.
tranetvpn1#show atm interface atm 0.2
Interface ATM0:
AAL enabled: AAL5 AAL2, Maximum VCs: 23, Current VCCs: 1
VCIs per VPI: 1024,
Max. Datagram Size: 4528
PLIM Type: ADSL - 832Kbps Upstream, DMT, TX clocking: LINE
15251 input, 18881 output, 121400 IN fast, 88626 OUT fast
Avail bw = 832
Config. is ACTIVE
tranetvpn1#
Right. in ADSL, A means Asymmetric.
You will also find that setting Cell Rate explicitly is not necessary, the router do that automatically.
I had to set the cell rate explicitly , otherwise it's not possible to put the service policy on the pvc.
I've been reading lots about atm, but I'm still confused, does the ubr rate command (say 'ubr 832') only apply to the upstream bandwidth?
Will this limit the rate that the router can transmit at, but it will still be able to receive data at rates up to 5Mb ?
Thanks for the reply
Yes, the command influences transmission only, and has no effect whatsoever on receiving.
