QOS CLI Changes on Cisco Router's
guruprasadr
Level 7
Level 7
Hello Experts,
Below provided is my QOS Config:
policy-map Customer-DMPLS
class voice
priority 256
class video
priority 1536
class data
bandwidth 896
class class-default
bandwidth 16384
The Show command output of my Policy-map:
Router#sh policy-map Customer-DMPLS
Policy Map Customer-DMPLS
Class voice
Strict Priority
Bandwidth 256
Class video
Strict Priority
Bandwidth 1536
Class data
Bandwidth 896
Class class-default
Bandwidth 16384
Question is:
In the QOS Configuration the VOICE & VIDEO class are reserved for Bandwidth using "Priority" words.
In the sh policy-map output the same are showing as: "Strict Priority" for VOICE & VIDEO Class.
Then, what is the exact difference between the "STRICT Priority" & "Priority" keywords on QOS.
Whether the CISCO has made changes in CLI only or how ?
Thanks in Advance for HELP.
Best Regards,
Guru Prasad R
4rmorris
The "priority" keyword turns on a strict priority queue. This means that not only is the queue prioritised to send traffic first, but it is also policed at the rate configured.
So unlike the "bandwidth" command, that allows traffic in the class to go beyond the configured value if available, traffic in the "priority" queue is capped at 256k or 1536k.
Keep in mind that there's only 1 priority queue. So in your case, voice and video go in the same queue, but will be policed at different rates.
R.
