03-09-2009 10:16 AM - edited 03-04-2019 03:52 AM
I have IP phones on a satellite network and would like to try cRTP header compression however the network topology is a C2811 router FE interface connecting to the satellite modem.
As far as I can tell RTP header compression is only available on slower speed serial links.
Is there an option for a FE Interface?
03-09-2009 10:31 AM
I'm not sure on the 2800 series, but on the 3745 you can run:
int fa0/0
ip rtp header-compression
HTH,
John
03-10-2009 07:19 AM
Thanks John I dont see that option on the 2800
c28(config-if)#ip rtp ?
priority Assign a priority queue for RTP streams
reserve Assign a reserved queue for RTP streams
