QoS configuration scenario over an MPLS backbone
mohammedmahmoud
Level 11
Level 11
Hi All,
I would like to discuss QoS configuration scenario over an MPLS backbone (Frame Mode MPLS over ATM Internetworking backbone using BPXs) for a provider to provide the MPLS VPN customer an appropriate QoS for their Voice traffic, my initial design is as follows:
CE-1 <-> PE-1 <-> P-1 <-> P-2 <-> PE-2 <-> CE-2
CE-1/CE-2:
Classification and Marking.(Egress)
LFI (MLPPP over FR) (Egress)
WRED (For class-default) (Egress)
FRTS (Egress)
LLQ (Egress)
PE-1/PE-1:
Remarking with MPLS Exp bits (Ingress from CE-1 to be used Egress to P-1, and then further on P-routers)
LLQ (on the egress facing CE-1 and P-1)
LFI (on the egress facing CE)
WRED (for class-default)
Policing (not CB-Policing, we shall rely on the ATM-PVC paramters)
P-1/P-2:
LLQ (Egress facing both PE and P)
WRED (class-default)
First of all, i need comments on this design. Second i've a couple of questions:
1. since the P router won't be aware about either the DSCP or the IPP how will WRED work on it ?
2. How will i configure the LLQ between the PE(s) and the P(s), will i have to calculate the aggregate estimate required bw and apply it in the LLQ ?
thanks in advance,
Mohammed.
ahmednaas
Level 4
Level 4
Mohammed,
I can't answer your questions but I'd like to draw your attention to the following cisco press book I came across recently. It looks like it might have some useful info for your topic, especially chapter 5 (Backbone Infrastructure):
QoS for IP/MPLS Networks
By Santiago Alvarez
Publisher: Cisco Press
Pub Date: June 02, 2006
Print ISBN-10: 1-58705-233-4
Print ISBN-13: 978-1-58705-233-0
Pages: 336
