QoS: Configuring the Modular Quality of Service CLI
haji_akhundov
Hello everyone!
I need some help regarding the configuration of QoS.
I have a switch(SLM224G) that is connected to a router (2811) (fast Ethernet sub interface, encap dot1Q3). Everything works just fine. MY end goal right now is to make certain physical ports on the switch to have a higher priority.
My proposed solution was to mark the packets on the switch with a CoS value and then use that information to classify the traffic.
For example,
I changed the switch's configuration to change mark interface e1 with CoS 3,
then the router with the following:
class-map match-all HI
match cos  3
policy-map MyPolicy
class HI
  priority percent 90
class class-default
  fair-queue
When I apply this to an interface:
interface fastethernet 0/0.2
service-policy output MyPolicy
I get: 'match cos' is not supported in an output policy
What's wrong here? How can I do this?
Thank you.
Giuseppe Larosa
Hello Haji,
change configurations so that  the switch marking is done assigning an OSI layer3 parameter like a DSCP value (this is mapped to the TOS-Diffserv byte in IPv4 header)
Then you change router configuration accordingly with the class defined matching on ip dscp instead of CoS
Hope to help
Giuseppe
Giuseppe,
Thank you for your reply.
It seems that I cannot make DSCP marking on my switch unfortunatly.
I tried an alternative way just now:
1. Mark CoS on a switch
2. match CoS on a router and SET dscp af11 (then apply as service-policy INPUT on a subinterface)
3. match DSCP af11 on a router set priority bandwidth et cetra (apply as OUTPUT)
class-map match-all dscpAF11
match  dscp af11
class-map match-all HI-PRI
match cos  5
policy-map marker
class HI-PRI
  set dscp af11
policy-map myQoS
class dscpAF11
  priority percent 90
class class-default
  fair-queue
interface FastEthernet0/0.3
encapsulation dot1Q 3
service-policy input marker
But now when I try to:
Router1(config)#int fastEthernet 0/0.3
Router1(config-subif)#service-policy output myQoS
I get:
CBWFQ : Not supported on subinterfaces
What I am doing at the moment seems logical to me..  But is there a special way of configuring logical interfaces?
haji_akhundov,
What is up man?
I see your message, i can help you.
"CBWFQ : Not supported on subinterfaces
What I am doing at the moment seems logical to me..  But is there a special way of configuring logical interfaces?"
you just have to configure a parente level at your policy, seems like this:
policy-map myQoS-child
class dscpAF11
  priority percent 90
class class-default
  fair-queue
policy-map myQoS-parent
class class-default
  shape average percent 100%
servisse-policy myQoS-child
service-policy output myQoS-parent
when you tested, please replay to me.
