QOS Default-Class
jsmcniel88
Level 4
Level 4
We are trying to limit the DFS replications and downloads to 30% of total bandwidth. I have setup the below QoS but for some reason the default-class policy take pryority and allows the DFS replications to consume up the the shape average of the default-class policy.
When i remove the shape avaerage from the default-class the DFS is trimmed back to the alloted 30%. As soon as the shape average is placed back on the default-class it allows it to go back up to 45.
Is there something I am missing in my policy?
access-list 105 permit ip host 10.144.241.231 any
access-list 105 permit ip any host 10.144.241.231
access-list 105 remark DFS-LIMIT
class-map match-all DFS-LIMIT-IN
match access-group 105
class-map match-any VOICE-CALL-CONTROL
match ip dscp af31
match ip dscp cs3
class-map match-any DFS-LIMIT
match ip dscp ef
match ip dscp cs5
class-map match-any ROUTING
match ip dscp cs6
policy-map WAN-EDGE
class VOICE
  priority 800
class VOICE-CALL-CONTROL
  bandwidth percent 1
class ROUTING
  bandwidth percent 1
class DFS-LIMIT
  shape average percent 30
class class-default
  fair-queue
  random-detect dscp-based
policy-map PARENT
class class-default
  shape average 45000000 3000000 1000
  service-policy WAN-EDGE
policy-map PARENT-IN
class DFS-LIMIT-IN
   police cir percent 25
   interface GigabitEthernet0/1.94
description AVPN 50MB/45MBCommit
bandwidth 409600
encapsulation dot1Q 94
ip address 10.144.250.49 255.255.255.252
ip accounting output-packets
service-policy input PARENT-IN
service-policy output PARENT
end
John Blakley
It looks like one of your class maps that reference your acl is set to "match-all" which is the default. You should remove this from your policy-map PARENT-IN and remove the class-map. Recreate it with "class-map match-any DFS-LIMIT-IN" and match on your same acl.
HTH,
John
HTH, John *** Please rate all useful posts ***
I will give that a try for the input. I should have mentioned that the Output on the interface is where i am seeing the 45 meg happen.
Does the output policy look correct?
It does look correct. Have you tried to remove the burst from the parent class-default? Try removing that and do just "shape average 45000000" and see what you get. When you do your test, can you post "show policy-map interface"?
HTH,
John
Implemented the suggested changes but still no luck:
show policy-map int gi 0/1.94
  Service-policy input: PARENT-IN
    Class-map: DFS-LIMIT-IN (match-any)
      1852586432 packets, 1089778262041 bytes
      5 minute offered rate 1104000 bps, drop rate 46000 bps
      Match: access-group 105
      police:
          cir 25 %
          cir 12800000 bps, bc 400000 bytes
        conformed 1682579435 packets, 874263917595 bytes; actions:
          transmit
        exceeded 162517555 packets, 214979009983 bytes; actions:
          drop
        conformed 1428000 bps, exceed 31000 bps
    Class-map: class-default (match-any)
      955282109 packets, 795440521315 bytes
      5 minute offered rate 11040000 bps, drop rate 0 bps
      Match: any
  Service-policy output: PARENT
      2077522094 packets, 1919295120644 bytes
      5 minute offered rate 11744000 bps, drop rate 129000 bps
      Match: any
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
         45000000/45000000  281250 1125000   1125000   25        140625
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         126215906 97741110  83351115  3541435327 yes
      Service-policy : WAN-EDGE
        Class-map: VOICE (match-any)
          16183 packets, 3526745 bytes
          5 minute offered rate 97000 bps, drop rate 0 bps
          Match: ip dscp ef (46)
            5 minute rate 97000 bps
          Match: ip dscp cs5 (40)
            0 packets, 0 bytes
            5 minute rate 0 bps
          Queueing
            Strict Priority
            Output Queue: Conversation 264
            Bandwidth 800 (kbps) Burst 20000 (Bytes)
            (pkts matched/bytes matched) 3337/727466
            (total drops/bytes drops) 0/0
        Class-map: VOICE-CALL-CONTROL (match-any)
          3726 packets, 792058 bytes
          5 minute offered rate 30000 bps, drop rate 0 bps
          Match: ip dscp af31 (26)
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: ip dscp cs3 (24)
            5 minute rate 30000 bps
          Queueing
            Output Queue: Conversation 265
            Bandwidth 1 (%)
            Bandwidth 450 (kbps)Max Threshold 64 (packets)
            (pkts matched/bytes matched) 671/166987
        (depth/total drops/no-buffer drops) 0/0/0
        Class-map: ROUTING (match-any)
          280 packets, 50499 bytes
          5 minute offered rate 0 bps, drop rate 0 bps
          Match: ip dscp cs6 (48)
            5 minute rate 0 bps
          Queueing
            Output Queue: Conversation 266
            Bandwidth 1 (%)
            (pkts matched/bytes matched) 50/9607
        Class-map: DFS-LIMIT (match-any)
          193183 packets, 282639580 bytes
          5 minute offered rate 6596000 bps, drop rate 0 bps
            5 minute rate 6596000 bps
          Traffic Shaping
                   30 (%)                0 (ms)      0 (ms)
             13500000/13500000  81000  324000    324000    24        40500
            -      0         0         0         0         0         no
          178602 packets, 36533798 bytes
          5 minute offered rate 785000 bps, drop rate 100000 bps
          Match: any
          Queueing
            Flow Based Fair Queueing
            Maximum Number of Hashed Queues 256
        (total queued/total drops/no-buffer drops) 0/2604/0
Extended IP access list 105
    10 permit ip host 10.144.241.231 any (2089518780 matches)
    20 permit ip any host 10.144.241.231 (1852722063 matches)
