QOS for DSCP Markings
TRACY HARTMANN
I have had QOS on some older routers and switches with the following commands
class-map match-all VOIP-SIGNALING
match dscp af41
class-map match-all VOIP-RTP
match dscp ef
policy-map VOIP
class VOIP-RTP
priority percent 15
class VOIP-SIGNALING
bandwith percent 3
These commands don't work on the new code, can you give me the commands that replaced this or can do this on the new code.
5 Replies 5
Collin Clark
What is your hardware platform and software version?
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Perhaps?
match ip dscp af41
match ip dscp ef
The cisco is a 3850 with version 3.2.2 se.
match dscp af41 command works.  I can't give the call a name so the first statement
class-map match-all VOIP-SIGNALING does't work
Then on the policy map when I try to use that class
Policy-map VOIP
Class VOIP-RTP               * because I can give the class map on name this statement does't work
priority percent 15             * this statement doesn't work
class VOIP-SIGNALING     * again this statement does work because of not being able to name it
bandwidth percent 5          * this statement doesn't work
I just tried it again and this is what I got in:
class-map match-any VOIP-SIGNALING
match dscp af41
class-map match-any VOIP-RTP
match dscp ef
policy-map VOIP
class VOIP-RTP
priority percent 15
          Error on this one that I can only use priority with level is supported on this platform?
bandwith percent 3
So I am assuming the any on the match will be fine, however what about the level error on the priority command?
Disclaimer
Posting
Oh, a 3850 L3 switch.  Likely its QoS MQC is much restrictive compared to a router.  I'm not familiar with that platform, but is IOS configuration guide probably has a section on QoS.  Have you reviewed that?
