QOS for Lync over 3925s
Leon Khanan
HI guys,
I have a DS3 line with two cisco 3925 ISRs on both ends of the private line. I need to create a QOS to allow any lync traffic ( that is marked with dscp of 26) to go with highest priority and always to have sufficient bandwidth over this 42meg pipe. Does anyone has samples or examples of how to do it?
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
class-map match-all lync
match dscp 26
policy-map sample
class lync
priority percent 33
interface (DS3)
service-policy output sample
Joseph W. Doherty
Disclaimer
Posting
match dscp 26
policy-map sample
class lync
priority percent 33
interface (DS3)
Joseph,
do i need to specify anything other than that? (bandwidth on the  serial int?)
is there anyway i can test that it is working?
Disclaimer
Posting
First, check to see if traffic is being matched.  Use the show policy interface command.
Second, if the interface is congested with non-Lync traffic (and not Lync traffic), pinging the other side using DSCP 26 should show very little increase vs. when interface isn't congested.
Thanks for the  help
