QOS for rdp traffic
sadoffrudoy1
Here is what I would like to do.....
We have an MPLS that connects our main office with our 7 branch offices.  We have 3Mb coming into the main office and 1.5 into all of the branch offices.  I would like to give rdp traffic the highest priority.  We have a Cisco 1841 at all branches and a Cisco 2811 at the main office. Do I have to configure QOS on all routers or just the one at the main location?  Any suggestions on the best way to configure this?
Mike
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
You probably should have an egress policy on all your sites, something like:
policy-map sample
class rdp
priority percent #
class class-default
fair-queue
You'll also want to find out from you MPLS vendor what QoS support they provide (sometimes an extra cost option), and then take advantage of it.
5 Replies 5
Alex Pfeil
Level 7
Level 7
I would think that you could just give port 3389 traffic the same dscp marking as voice traffic. I would set it up I GNS3 and test it first.
Yes, setup qos at all sites
Joseph W. Doherty
Disclaimer
Posting
policy-map sample
class rdp
priority percent #
class class-default
fair-queue
Thanks for all the replies.  Do I put this egress policy on the serial interface of all the routers?  Is it exactly the same on all the routers?
Thanks again.
Disclaimer
Posting
Yes, policy would be applied to outbound egress interface, i.e. probably your serial interfaces.
A policy like the the "sample" might be applied to all routers, unless you need different percentage or want to deal with some special traffic that's unique per site.
Great, thanks.
