08-28-2019 07:14 PM
We've recently setup a RDS environment and would like to do a basic QoS rule to prioritize rdp traffic, but I'm not sure the best way to do this. We have a 100Mpbs fiber connection (soon to be 250) and our setup is like this ISP->WAN router->WAN Switch->2 different ASAs.
We have an ASA for our main corp environment and then an ASA for our RDS environment. From what I've read it seems like the best way to do this would be to put the QoS on the WAN router. I should note that the RDP traffic goes over a site to site VPN from the RDS side ASA firewall to the site where the users are at. If need be making QoS for everything from that RDS ASA public IP would work as well. Basically I want to prioritize all traffic as such
Priority 1 Voice traffic from our Corp ASA
Priority 2 RDP Traffic from the RDS ASA
Is this something that would be simple to setup?
Thank you in advance
Solved! Go to Solution.
09-16-2019 11:01 AM
09-16-2019 12:29 PM
would this work? Then just make an access list for each group/IP I want to set?
class-map match-all VoIP
description Voice Traffic
class-map match-all RDS
description RDS Traffic
class-map match-all Corporate
description Corp Office
class-map match-all Class-Default
class-map match-all Priority
policy-map VoIP
class VoIP
bandwidth percent 1
policy-map RDS
class RDS
bandwidth percent 8
policy-map Corporate
class Corporate
bandwidth percent 10
Policy-map Default
class class-default
bandwidth percent 81
ip access-list extended VoIP
permit ip host 45.45.45.1
policy-map shape
09-16-2019 01:37 PM
09-16-2019 02:28 PM
Thank you for your continued help.
I've built this in packet tracer and can't seem to figure out how to add the IP to the extended ACL
Router#show run
Building configuration...
Current configuration : 1381 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15244G7R
spanning-tree mode pvst
description Default
policy-map VoIP
class VoIP
bandwidth percent 1
policy-map RDS
class RDS
bandwidth percent 8
class Corporate
policy-map Class-Default
class class-default
bandwidth remaining percent 100
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
permit ip host 45.45.45.1 any
ip access-list extended RDS
permit ip host 45.45.45.2 any
ip access-list extended Corporate
permit ip host 45.45.45.3 any
ip access-list extended Default
permit ip any any
line con 0
line aux 0
line vty 0 4
login
end
09-16-2019 03:15 PM
09-17-2019 06:11 AM
I set it up on a 2901 router with IOS 15.4.3 and still no luck.
I'm not sure where I've botched this up. Any ideas on where I could see an example of what I'm trying to do? I've searched on Google but can't seem to find it where it's done by IP and not service type.
Thank you
09-17-2019 08:36 AM
09-17-2019 09:41 AM
It's the same config I put in the packet tracer.
Here are my options
Router(config)#ip access-list extended VoIP
Router(config-ext-nacl)#?
<1-2147483647> Sequence Number
default Set a command to its defaults
deny Specify packets to reject
exit Exit from access-list configuration mode
no Negate a command or set its defaults
permit Specify packets to forward
remark Access list entry comment
09-17-2019 04:44 PM
09-18-2019 06:22 AM
Correct, I am unable to assign the class-map to the ACL.
09-18-2019 08:06 AM
09-18-2019 08:32 AM
match access-group 10
description Default
policy-map VoIP
class VoIP
bandwidth percent 1
policy-map RDS
class RDS
bandwidth percent 8
class Corporate
class class-default
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
permit ip any any
Ok, I think we are close. One more issue when I assign the ACL to the class-map match-all it won't let me put in the work "VoIP" at the end of "match access-group" says invalid input dtected at marker.
I did a
Router#show access-lists
Extended IP access list VoIP
10 permit ip host 45.45.45.1 any
Extended IP access list RDS
10 permit ip host 45.45.45.2 any
Extended IP access list Corporate
10 permit ip host 45.45.45.3 any
Extended IP access list Default
10 permit ip any any
It allows me to put 10 in at the end, however thye are all 10. Why are they all the same ACL #?
Thank you again for all the help on this issue!
09-18-2019 09:16 AM
09-18-2019 10:30 AM
ok, I see what you mean on the Policy-map. I will combine those into one and add classes under it.
Let me get that done then I'll show you my config. I'm still a little puzzled.
Thank you
09-18-2019 10:36 AM
Ok, here is the new config. However I still don't know how to do the ACL's. Also on the ACL do you need any deny statements?
description Default
policy-map Traffic_QoS
class VoIP
bandwidth percent 1
class Corporate
class RDS
class class-default
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
permit ip any any
