QoS for Tunnel source loopback
Anton Pestov
Where to apply policy-map when GRE Tunnel Interface have "tunnel source Loopback" ?
- to Physical interface (corresponds to a routing table for GRE IP header DestIP)?
or
- to Loopback interface?
Example. Where to apply policy-qos-test-parent:
policy-map policy-qos-test
 class class-qos-test-dscp
  priority percent 10
 class class-default
  fair-queue
  random-detect dscp-based
  random-detect ecn
policy-map policy-qos-test-parent
 class class-default
  shape average percent 85
   service-policy policy-qos-test
interface GigbitEthernet 0/1
 ip add 10.10.10.1 255.255.255.252
interface Loopback 0
 ip add ...
interface Tunnel999
 bandwidth 10240
 ip add ....
 tunnel source Loopback0
 tunnel destination 10.10.10.2
Joseph W. Doherty
On the tunnel interface or the physical egress interface; not on the loopback interface.
BTW, as you're using FQ, FQ won't "see" flows if you apply the policy on the physical egress interface unless you also use the qos pre-classify command on the tunnel interface.
Joseph W. Doherty
If to apply policy on the Physical interface, then also it is necessary to specify actual 'bandwidth ...' parameter, that parent policy shaper correctly worked?
Depends on whether you're using CBWFQ/shaper that supports using percentages, and have configured bandwidth as percentages.
