QoS for Video conferencing
ja raju
Hi guys,
I'm having some issues with classifying video conference traffic for QoS on our WAN link.
This is the config i'm using: (partial)
class-map match-any VIDEO
match protocol rtp video
policy-map QoS-Policy
class VIDEO
    bandwidth 1024
  set ip dscp cs5
policy-map WAN-10M
class class-default
    shape average 10485760
  service-policy QoS-Policy
interface GigabitEthernet0/0
bandwidth 10000
ip address <ip> 255.255.255.252
ip nbar protocol-discovery
ip flow ingress
load-interval 30
duplex full
speed 100
media-type rj45
service-policy output WAN-10M
Then I got the users to test making video calls from their Cisco phones to a remote site via the WAN link but I don't see any packets matching the VIDEO class.
wanrtr#sh policy-map int g0/0 output class VIDEO
GigabitEthernet0/0
  Service-policy output: WAN-10M
    Class-map: VIDEO (match-any)
      0 packets, 0 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: protocol rtp video
        0 packets, 0 bytes
        30 second rate 0 bps
          Queueing
          queue limit 64 packets
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 0/0
          bandwidth 1024 kbps
      QoS Set
        dscp cs5
          Packets marked 0
Any idea why there's no match on rtp video?
Thanks in advance.
John Blakley
Does nbar show matches on rtp video?
show ip nbar protocol-discovery
If it's not showing video there, then you may not be marking those packets like that. I don't have Cisco phones in our environment (that do video as well). Is there a way that you can match on the specific subnet and cs marking that the phone provides instead of using nbar? And as a side note I believe video should generally be marked to CS4 instead of 5 so it doesn't crossover into your voice traffic.
HTH, John *** Please rate all useful posts ***
I only see "rtp". It does not specify whether it's rtp-video, audio, etc. If there's no way around this, I would need to use ACL to mark the traffic instead. Yea I think I'm going to mark video as cs4 instead of cs5, thanks for that
wanrtr#show ip nbar protocol-discovery
GigabitEthernet0/0
Last clearing of "show ip nbar protocol-discovery" counters 3d19h
                            Input                    Output
   Protocol                 Packet Count             Packet Count
                            Byte Count               Byte Count
                            30sec Bit Rate (bps)     30sec Bit Rate (bps)
                            30sec Max Bit Rate (bps) 30sec Max Bit Rate (bps)
   rtp                      11242371                 25957872
                            2247292882               3607790125
                            649000                   731000
                            2471000                  2166000
