QoS for video over mpls
John Blakley
*** Moved from Video Over IP group ****
All,
I'm about to set up a video  conference system between branches over our provider's mpls network. It  would look like the following:
video equip (10.5.5.5) -> (fa0/1) branch  (s0/0) -> provider -> (s0/0) corp (fa0/1) -> video equipment  (10.7.7.7)
QoS  has been applied at both ends (Branch/Corp) from the provider's  viewpoint. I need to know how the best way to handle qos would be. Below  is what I'm thinking:
Branch router:
access-list 20 permit host 10.5.5.5
class  Inbound
match ip address 20
class outbound
match ip dscp af41
policy-map  Inbound
set dscp af41
policy-map Outbound
bandwidth 512k
int fa0/1
service-policy  input Inbound
int  S0/0
service-policy output Outbound
This is all from my head above, so I  figure the syntax isn't 100% correct. My goal is to ensure that the  incoming traffic from the device is marked with AF41. On the Corp side, I  would have another policy map INBOUND that states to match on the AF41  and then I'm assuming that I would set my bandwidth statements on  Outbound on the Corp fa0/1 side? That's where I'm confused.
Thanks!
John
HTH, John *** Please rate all useful posts ***
Edison Ortiz
There is no need to match inbound at the CORP side.
You simply apply the same syntax but on the return traffic from the CORP side.
For instance
access-list 20 permit host 10.7.7.7
class  Inbound
match ip address 20
class outbound
match ip  dscp af41
policy-map   Inbound
set dscp af41
policy-map Outbound
bandwidth 512k
int fa0/1
int   S0/0
Edison Ortiz
For instance
class  Inbound
match ip address 20
class outbound
match ip  dscp af41
policy-map   Inbound
set dscp af41
policy-map Outbound
bandwidth 512k
int fa0/1
int   S0/0
Thanks Edison.....
