ā11-16-2011 11:35 AM - edited ā03-04-2019 02:18 PM
Hi, I need to apply qos for 128 Kbps bandwidth ,only at the CE end , where in 64Kbps should be for voice traffic ,
in case voice isnt there then remaining should be allocated for Data.
Will this help me in case QoS is only applied at the CPE end.
Solved! Go to Solution.
ā11-16-2011 08:43 PM
Hi Nihit,
Applying QoS only at CPE can help you in your requirement.
However, if your ISP don't honour your marking, then their won't be end to end reservation of bandwidth.
In simple terms, you will be allocation 64kbps only at CPE and once traffic leaves your Router, there won't be any gaurantee of PE or P router allocating same bandwidth to voice traffic
HTH,
Smitesh
Hi Nihit,
HTH,
Smitesh
ā11-16-2011 09:55 PM
Hi Smithesh,
Thanks for replying, can you help me with the sample config to be applied.
ā11-16-2011 11:22 PM
Hi Nihit,
What is your VoIP setup and how it is connected o router / switch ??
Sample config can be (assumption that you use different IP Subnet for VoIPs)
*** Below config will classify the packets***
ip access-list 10 permit
*** Below config will mark the packets ***
class-map VoIP
match access-group 10
exit
*** Below config will reserve the required bandwidth ***
policy-map VoIP
class VoIP
bandwidth 64
exit
int
service-policy output VoIP
exit
HTH,
Smitesh
