Cisco 1941/K9 PPPoE Configuration
fcholayil
Can you please advise me how to configure the Cisco 1941 router for PPPOE with dynamic IP
10 Replies 10
paolo bevilacqua
Have you considered searching either in this forum, or in the many configuration examples on cisco.com?
That would give you an immediate solution, instead of having to wait for others to answer.
Dear,
I did the configuration but the internet in not working, please advise me
My Task is Configure PPPOE -ISP Dynamic IP
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#no ip http server
Router(config)#vpdn enable
Router(config)#vpdn-group ppoe
Router(config-vpdn)#request-dialin
Router(config-vpdn-req-in)#protocol LPT12
Router(config-vpdn-req-in)#exit
Router(config-vpdn)#exit
Router(config)#interface ethernet0
Router(config-if)#ip address 10.10.10.1 255.255.255.0
Router(config-if)#ip nat inside
Router(config-if)#no shutdown
Router(config-if)#exit
Router(config)#interface Dialer 0
Router(config-if)#pvc
Router(config-if-atm-vc)#pppoe-client dial-pool-number 1
Router(config-if-atm-vc)#exit
Router(config)#int dialer 0
Router(config-if)#ip address negotiated
Continue with the rest of command
Router(config-if)#ip mtu 1492
Router(config-if)#ip nat outside
Router(config-if)#dialer pool 0
Router(config-if)#ppp authentication pap callin
Router(config-if)#ppp pap sent-username password
Router(config)#ip nat inside source list 1 interface dialer 0 overload
Router(config)#ip classless
If you are assigned a dynamic IP address by your ISP, then follow this command
Router(config)#ip route 0.0.0.0 0.0.0.0 dialer 1
Router(config)#access-list 1 permit 10.10.10.1 0.0.0.255
Router(config)#exit
Appriciated if some one can help on this issue
Post configuration, not console log.
vpdn commands are not needed.
Hi Faisal,
I assume you are trying to configure the 1941 as PPPoE client, is that correct?
The configuration you pasted below doesn't make much sense to me, you are trying to configure L2TP protocol instead of PPPoE.
This is a basic configuration that you can use on a PPPoE client:
interface fa0/0   <<< your link to the ISP
pppoe enable
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname user@test.com
ppp chap password 0 test
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
Hope this helps
Marco
Thanks Marco,
your right, here my current conf, is right?
no ip bootp server
ip domain name Gargash_1941
ip name-server 213.42.20.20
ip name-server 195.229.241.222
interface GigabitEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$ES_WAN$
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1
description $ES_LAN$
ip address 192.168.2.99 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
interface Dialer0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname pass@domain.com
ppp chap password 7 08324F41191C0C19112322
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.2.0 0.0.0.255
access-list 23 permit 192.168.1.0 0.0.0.255
Kind regards
faisal
1. If gigaeth0/0 is your WAN interface, then configure it in this way:
pppoe enable
2. Remove dialer 0 ("no interface dialer 0")
3. Add "ip nat outside" to dialer 1
4. Correct the nat statement to use dialer 1 instead of dialer 0
Thank you, let me try this way
Dear Marco,
Thank you for the great support, appriciated
once agian i did all thos conguration but still i cannot access,
I'm attaching the current configuration,
Please help me
Faisal Cholayil
hi,
may i know that for this router Cisco 1941/K9, existing already have 2 GigabitEtherface, if i want to connect to modem port which use to dial up to static IP, with pppoe username and password, do i really need to purchase HWIC-1FE?
Can i use the existing GigabitEtherface rather than purchase HWIC-1FE card?
nobody reply me
anyway, i found out the answer, yes, it can, as both HWIC and Gigabitethernet card can support same command, just one support up to 100Mbps, one support up to 1000Mbps
