-= QoS for VoIP... Is this correct or am I doing it wrong =-
rkendrick_2
I'd like to know if I'm doing QoS correctly between 2 sites (Lincoln and Raleigh). We are doing VoIP (using SIP and RTP) between both sites with the only other protocol being TCP 2633 (i3CLIENT). The i3CLIENT traffic is the desktop software that runs on each users desktop. It tells the users when a call comes in and information about the customer on the phone before the user actually answers the call.
Our network is a frame-relay network. Each site, Raleigh/Lincoln, has 3 T1 circuits with a PVC talking to the upstream end with a CIR of 1536. I chose to do IP CEF per-packet to aggregate the T1s but would prefer to do MLPoFR. My issue is sometimes the users complain of the i3 client running slow. When I do 'show policy-map int xxx' I see that the Voice has no drops but the Trans policy-map is dropping roughly 26% of traffic. I'd like to tweak the Trans (i3CLIENT) stuff to not drop so much BUT insure that the VOICE gets all the bandwidth it needs. I wasn't sure if I needed to create the service policy for a 1536 shape average or 4608 shape average. The only other protocols that flow between these 2 sites is probably ping and SIP.
Should I attempt MLPoFR to cut down on jitter? How would I do it based on my config? According to our users, call quality sounds great but I'm not sure if I'm doing it efficiently or correctly.
The below attachment is from the Raleigh router (The Lincoln router is mirror-image):
no ip source-route
ip nbar port-map i3CLIENT tcp 2633
ip cef
class-map match-any SDMTrans-Serial0/0/0.1
match protocol i3CLIENT
class-map match-any SDMVoice-Serial0/0/0.1
match protocol rtp audio
class-map match-any SDMSignal-Serial0/0/0.1
match protocol h323
match protocol rtcp
policy-map SDM-Pol-Serial0/0/0.1
class SDMVoice-Serial0/0/0.1
priority percent 50
set dscp ef
class SDMSignal-Serial0/0/0.1
set dscp cs3
bandwidth remaining percent 15
class SDMTrans-Serial0/0/0.1
set dscp af21
bandwidth remaining percent 65
policy-map SDM-Pol-Serial0/0/0.1-FR
class class-default
shape average 1536000
service-policy SDM-Pol-Serial0/0/0.1
interface GigabitEthernet0/0
description Raleigh-LAN
ip address 17.6.0.35 255.255.240.0
ip accounting output-packets
ip route-cache flow
load-interval 30
duplex full
speed 100
interface Serial0/0/0
description DLCI227
bandwidth 1536
encapsulation frame-relay
no fair-queue
interface Serial0/0/0.1 point-to-point
description PVC-RALtoLIN-VOIP (DLCI227->126)
ip address 172.17.4.30 255.255.255.252
ip nbar protocol-discovery
ip load-sharing per-packet
snmp trap link-status
frame-relay interface-dlci 126
frame-relay ip tcp header-compression
frame-relay ip rtp header-compression
service-policy output SDM-Pol-Serial0/0/0.1-FR
interface Serial0/0/1
description (DLCI 228)
bandwidth 1536
no fair-queue
interface Serial0/0/1.1 point-to-point
description PVC-RALtoLIN-VOIP (DLCI228->222)
ip address 172.17.4.34 255.255.255.252
frame-relay interface-dlci 222
interface Serial0/1/0
description (DLCI 229)
bandwidth 1536
no fair-queue
interface Serial0/1/0.1 point-to-point
description PVC-RALtoLIN-VOIP (DLCI229->223)
ip address 172.17.4.38 255.255.255.252
frame-relay interface-dlci 223
ip route 0.0.0.0 0.0.0.0 Null0
ip route 17.8.0.0 255.255.240.0 172.17.4.29
ip route 17.8.0.0 255.255.240.0 172.17.4.33
ip route 17.8.0.0 255.255.240.0 172.17.4.37
rkendrick_2
Below is 'show policy-map' from one of the interfaces:
RAL-VoIP#sh policy-map int s0/0/0.1
Serial0/0/0.1
Service-policy output: SDM-Pol-Serial0/0/0.1-FR
Class-map: class-default (match-any)
4873515 packets, 598900584 bytes
30 second offered rate 595000 bps, drop rate 4000 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
1536000/1536000 9600 38400 38400 25 4800
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 4852502 562996175 771773 140656035 no
Service-policy : SDM-Pol-Serial0/0/0.1
Class-map: SDMVoice-Serial0/0/0.1 (match-any)
3698423 packets, 236682376 bytes
30 second offered rate 274000 bps, drop rate 0 bps
Match: protocol rtp audio
3698424 packets, 236682440 bytes
30 second rate 274000 bps
Queueing
Strict Priority
Output Queue: Conversation 72
Bandwidth 50 (%)
Bandwidth 768 (kbps) Burst 19200 (Bytes)
(pkts matched/bytes matched) 387964/24828408
(total drops/bytes drops) 0/0
QoS Set
dscp ef
Packets marked 3698424
Class-map: SDMSignal-Serial0/0/0.1 (match-any)
21389 packets, 3955462 bytes
30 second offered rate 3000 bps, drop rate 0 bps
Match: protocol h323
6392 packets, 2415554 bytes
30 second rate 1000 bps
Match: protocol rtcp
14997 packets, 1539908 bytes
QoS Set
dscp cs3
Packets marked 21389
Queueing
Output Queue: Conversation 73
Bandwidth remaining 15 (%)Max Threshold 64 (packets)
(pkts matched/bytes matched) 4058/1030098
(depth/total drops/no-buffer drops) 0/0/0
Class-map: SDMTrans-Serial0/0/0.1 (match-any)
1070381 packets, 348254349 bytes
30 second offered rate 311000 bps, drop rate 4000 bps
Match: protocol secure-telnet
0 packets, 0 bytes
30 second rate 0 bps
Match: protocol ssh
0 packets, 0 bytes
Match: protocol telnet
0 packets, 0 bytes
Match: protocol custom-01
30 second rate 311000 bps
QoS Set
dscp af21
Packets marked 1070381
Queueing
Output Queue: Conversation 74
Bandwidth remaining 65 (%)Max Threshold 64 (packets)
(pkts matched/bytes matched) 390412/117535689
(depth/total drops/no-buffer drops) 0/21015/0
83323 packets, 10008461 bytes
30 second offered rate 5000 bps, drop rate 0 bps
Match: any
I will suggest you specify bandwidth for guaranteed bandwidth statements and not use
"bandwidth remaining percent" command. use specific banwidth value.
e.g to give the application and vocie signalling 128 each the policy-map will be as follows.
priority percent 50
set dscp ef
set dscp cs3
bandwidth 128
set dscp af21
bandwidth 128
class class-default
What happens when the Trans traffic exceeds 128kbps? Will it drop the traffic heavily?
