QoS HQF (3 Level) Configuration
zakir.ahmed
I would like to share a 2 level QoS config first and then the same config using 3 level -
! Example 1
class-map match-any C-EF
match  dscp cs5  ef
class-map match-any C-AF4
match  dscp cs4  af41  af42  af43
class-map match-any C-AF3
match  dscp cs3  af31  af32  af33
class-map match-any C-AF2
match  dscp cs2  af21  af22  af23
class-map match-any C-AF1
match  dscp cs1  af11  af12  af13
policy-map CHILD-POLICY-1
class C-EF
  priority percent 20
class C-AF4
  bandwidth remaining percent 25
class C-AF3
class C-AF2
  bandwidth remaining percent 24
class C-AF1
policy-map 2-LEVEL
class class-default
  shape average 10000000
  service-policy CHILD-POLICY-1
interface FastEthernet0
service-policy output 2-LEVEL
#show policy-map interface fastEthernet0
FastEthernet0
  Service-policy output: 2-LEVEL
    Class-map: class-default (match-any)
      9 packets, 1271 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 9/1313
      shape (average) cir 10000000, bc 40000, be 40000
      target shape rate 10000000
      Service-policy : CHILD-POLICY-1
        queue stats for all priority classes:
          (pkts output/bytes output) 0/0
        Class-map: C-EF (match-any)
          0 packets, 0 bytes
          Match:  dscp cs5 (40) ef (46)
            0 packets, 0 bytes
            30 second rate 0 bps
          Priority: 20% (2000 kbps), burst bytes 50000, b/w exceed drops: 0
        Class-map: C-AF4 (match-any)
          0 packets, 0 bytes
          Match:  dscp cs4 (32) af41 (34) af42 (36) af43 (38)
            0 packets, 0 bytes
          Queueing
          bandwidth remaining 25% (2000 kbps)
        Class-map: C-AF3 (match-any)
          0 packets, 0 bytes
          Match:  dscp cs3 (24) af31 (26) af32 (28) af33 (30)
            0 packets, 0 bytes
          Queueing
        Class-map: C-AF2 (match-any)
          0 packets, 0 bytes
          Match:  dscp cs2 (16) af21 (18) af22 (20) af23 (22)
            0 packets, 0 bytes
          Queueing
          bandwidth remaining 24% (1920 kbps)
        Class-map: C-AF1 (match-any)
          0 packets, 0 bytes
          Match:  dscp cs1 (8) af11 (10) af12 (12) af13 (14)
            0 packets, 0 bytes
          Queueing
          Match: any
! Example 2
match  dscp cs5  ef
class-map match-any C-AF4-AF3
match  dscp cs4  af41  af42  af43 cs3  af31  af32  af33
class-map match-any C-AF2-AF1
match  dscp cs2  af21  af22  af23 cs1  af11  af12  af13
policy-map AF4-AF3-CHILD
class C-AF4
  bandwidth remaining percent 50
class C-AF3
  bandwidth remaining percent 49
policy-map AF2-AF1-CHILD
class C-AF2
class C-AF1
policy-map CHILD-POLICY-2
class C-EF
  priority percent 20
class C-AF4-AF3
  service-policy AF4-AF3-CHILD
class C-AF2-AF1
  bandwidth remaining percent 48
  service-policy AF2-AF1-CHILD
policy-map 3-LEVEL
class class-default
  service-policy CHILD-POLICY-2
service-policy output 3-LEVEL
FastEthernet0
  Service-policy output: 3-LEVEL
      162 packets, 17737 bytes
      Match: any
      Queueing
      (pkts output/bytes output) 162/18081
      Service-policy : CHILD-POLICY-2
          0 packets, 0 bytes
            0 packets, 0 bytes
        Class-map: C-AF4-AF3 (match-any)
          0 packets, 0 bytes
          Match:  dscp cs3 (24) af31 (26) af32 (28) af33 (30) cs4 (32) af41 (34) af42 (36) af43 (38)
            0 packets, 0 bytes
          Queueing
          bandwidth remaining 50% (4000 kbps)
          Service-policy : AF4-AF3-CHILD
              0 packets, 0 bytes
                0 packets, 0 bytes
              Queueing
              bandwidth remaining 50% (2000 kbps)
              0 packets, 0 bytes
                0 packets, 0 bytes
              Queueing
              bandwidth remaining 49% (1960 kbps)
              0 packets, 0 bytes
              Match: any
        Class-map: C-AF2-AF1 (match-any)
          0 packets, 0 bytes
          Match:  dscp cs1 (8) af11 (10) af12 (12) af13 (14) cs2 (16) af21 (18) af22 (20) af23 (22)
            0 packets, 0 bytes
          Queueing
          bandwidth remaining 48% (3840 kbps)
          Service-policy : AF2-AF1-CHILD
              0 packets, 0 bytes
                0 packets, 0 bytes
              Queueing
              bandwidth remaining 50% (1920 kbps)
              0 packets, 0 bytes
                0 packets, 0 bytes
              Queueing
              bandwidth remaining 49% (1881 kbps)
              0 packets, 0 bytes
              Match: any
          Match: any
In both examples (2-Level and 3-Level), the five classes (EF/AF4/AF3/AF2/AF1) are allocated almost the same amount of bandwidth. During the congestion period, if there is no traffic in the AF4 Class the unused bandwidth (2000 kbps) will be shared between AF3, AF2, and AF1 classes (first example - 2-Level).
But in the 2nd example (3-Level), if there is no traffic in the AF4 class during the congestion period, the unused bandwidth (2000 kbps) will be used by the AF3 class first because AF3 and AF4 are under the same parent class C-AF4-AF3 (4000 Kbps). The unused bandwidth from AF4 class will not be shared with AF2 and AF1 as long as AF3 class needs 50% (4000 Kbps) of the link bandwidth.
Please confirm if my understanding is correct.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
I believe your understanding is incorrect.
What CBWFQ really does is assign a weight to the flows.  It uses that weight relative to other flows for bandwidth scheduling.
In both your 2 layer and 3 layer polices, your four classes would get about the same weight, so they will all be processed alike regardless of whether the defining policy was 2 layer or 3 layer.
