QOS in Cisco 4506
cindylee27
Hi Experts,
Would like to know if QOS can be configured on Cisco 4506.
The sh ver as below:
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5S-M), Version 12.2(25)EWA5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 17-Nov-05 16:24 by alnguyen
Image text-base: 0x10000000, data-base: 0x114E2164
ROM: 12.2(31r)SG3
Dagobah Revision 226, Swamp Revision 32
SGCTHSR-SC001004 uptime is 19 weeks, 4 days, 14 hours, 38 minutes
System returned to ROM by reload
System restarted at 18:05:57 gmt Sat Oct 20 2007
System image file is "bootflash:cat4000-i5s-mz.122-25.EWA5.bin"
cisco WS-C4506 (MPC8245) processor (revision 14) with 524288K bytes of memory.
Processor board ID FOX11290EVD
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from Reload
56 Virtual Ethernet interfaces
48 FastEthernet interfaces
98 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Basically,
I tried to configure as below but to no avail...
policy-map Test-QOS-WAN
class class-2-QoS
set ip dscp af32
bandwidth remaining percent 35
queue-limit 50
class class-4-QoS
set ip dscp af12
bandwidth remaining percent 10
queue-limit 40
class class-1-voip
set ip dscp ef
priority 40
class class-2-signaling
set ip dscp cs3
queue-limit 40
class class-default
set ip dscp default
bandwidth remaining percent 45
queue-limit 40
cindylee27
Anyone can help?
jasosan22
Do you have it "applied" to an interface? What to you get if you do a ? Are you marking COS?
Hi Jasosan,
Yes, I applied it on interface. What you mean by marking COS?
Am trying to find command of Bandwidth Percent Remaining but it is not available in Cisco 4506 Switch but there is QOS inside.
I am just wondering where did I go wrong..
Thanks again.
Although the Catalyst 4500 runs IOS, you must be careful when configuring features such as QoS.
QoS on Catalyst switches have a lot of dependencies such as Supervisor, Modules and IOS version.
I highly suggest you take a moment and read how QoS is done for your IOS version. Within that document there are some caveats mentioned on specific hardware (modules) for the Cat4500.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25ewa/configuration/guide/qos.html#wp1271596
HTH,
__
Edison.
