QoS - In class-map config cannot issue a match port tcp command
keithsauer507
Level 5
Level 5
Cisco 2901 router,
Issue:  VMWare vSphere replication has no means to throttle traffic until upgrading to 6.0 release which we are not ready to do yet.
Solution: Would like to throttle this traffic out our WAN through our 2901 router.  The existing traffic uses destination ports 39444 and 44046.
I thought that if I was in a class-map config, I could do something like
match port tcp eq 39444
But I get % Invalid input detected at '^' marker.
Any idea how to set this up?
Mark Malone
You could match against an access-list that permits devices only with those port numbers to be match against
something like
class-map TEST
match access-group TEST
access-list TEST permit tcp .......... eq 39444
Mark Malone
something like
class-map TEST
As Mark shows.
Thank you, that makes sense!
