QOS - in service-policy command, missing input,output in 2901 router
ciscoroyzhang
hi group,  try to assign the service policy to a VPN tunnel, but can not find the input or output option. this is a brandnew  2901 router for branch office and it comes with ADSL link to internet, based on that link, a VPN tunnel created and pointed to DMVPN in HQ. see following for detail:
          sel01-rt01(config-if)#service-policy ?
                 type  type of the policy-map
         following opiotn is missing:
                history  Keep history of QoS metrics
               input    Assign policy-map to the input of an interface
               output   Assign policy-map to the output of an interface
    any suggestion?  cheers Roy
information about the router
     router: "CISCO2901/K9"
     adsl card: EHWIC-VA-DSL-A
     IOS version: Version 15.2(4)M4,
      interface connfiguration:
     controller VDSL 0/0/0
     interface ATM0/0/0
      description ***DMVPN to HQ***
      bandwidth 1024
      no ip address
      ip flow ingress
      no atm ilmi-keepalive
      pvc 8/35
       encapsulation XXXXXX  ppp dialer
       dialer pool-member 1
interface Dialer0
      bandwidth 1024
      ip address negotiated
      ip accounting output-packets
      ip flow ingress
      encapsulation ppp
      dialer pool 1
      ppp authentication chap callin
      ppp chap hostname XXXXXX
      ppp chap password 7 XXXXXXX
     end
interface Tunnel1
description *** to DMVPN HQ ***
bandwidth 1024
ip address XXXX XXXX
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1388
ip nhrp authentication XXXX
ip nhrp map multicast dynamic
ip nhrp map XXXX
ip nhrp map multicast  XXXX
ip nhrp network-id XXXX
ip nhrp nhs XXXX
ip nhrp shortcut
ip nhrp redirect
ip tcp adjust-mss 1348
tunnel source Dialer0
tunnel mode gre multipoint
tunnel protection ipsec profile XXXXX
lmediavilla
you cannot apply policy maps to th eatm because is not an IP interface, you should do it on the dialer (and most routers just output (#service-policy output mypolicy)
or if its traffic going to the hub on the tunnel interface
cheers
