VRF-aware syslogging with 2921
johnnylingo
Level 5
Level 5
I typically use a VRF for management of border routers, partially for secure access via SSH/SNMP, and partially so they can send syslog traps to the syslog server without setting up firewall rules and NATs.
This works fine with a 6500, but trying to use the same configuration on a 2921 I have no luck.  Connectivity seems to be there but I see no messages going through.  TACACs is also configured to use the VRF and works just fine, so the issue is specific to syslog.
#show run | inc vrf MGMT
ip vrf MGMT
ip route vrf MGMT 0.0.0.0 0.0.0.0 10.100.1.1
logging source-interface Port-channel1.100 vrf MGMT
logging host 10.200.3.4 vrf MGMT
#ping vrf MGMT 10.200.30.4
Sending 5, 100-byte ICMP Echos to 10.200.30.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/8 ms
IOS version is 15.1(4)M7
lmediavilla
is it port-channel 1.100 on vrf MGMT?
if not that's the problem
it it is.... the config is good so you should try using a loopback in vrf MGMT because probably a bug is causing that problem
kind regards
