QOS into GRE Tunnel on 6500's
dmooreami
Level 3
Level 3
running 6500's with IOS 12.2(14) and CatOS 8.3(2).
My 6500's are where the GRE tunnels are endpointed before they are sent over my IPsec tunnel that is created on the PIX/ASA's.
Need something simple if possible to give video conferencing more priority in the tunnel, or shave off 1meg for just H.263/.264 protocols. Can someone point me here on cisco.com where I might find how to do this? It doesn't have to be "QOS" per say but priority queuing or just something that will push H.26x first down the GRE tunnel. Thanks
wdrootz
Level 4
Level 4
To configure the queuing on 6500, you can use the output scheduling feature.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801091a5.shtml
To know about all the QoS features available in 6500, you can refer to
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/qos.html
