QoS Issue or perhaps a bug
dennylester
I am trying to apply QoS on a multilink interface (two T1's)
This is what I originally applied and the router accepted it.
class-map match-all ipprec_4
match ip precedence 4
class-map match-all ipprec_3
match ip precedence 3
class-map match-all ipprec_2
match ip precedence 2
policy-map pobshaping
class ipprec_4
priority percent 50
class ipprec_3
priority percent 25
class class-default
fair-queue
After looking the policies over, I decided I wanted to adjust the bandwidth, so I issued a
no policy-map pobshaping
and recreated it as shown below
class ipprec_4
priority percent 50
class ipprec_3
priority percent 10
class class-default
fair-queue
When I went to apply this to the multilink interface the router generated this error
I/f Multilink1 class ipprec_3 requested bandwidth 10%, available only 0%
Suspending service policy pobshaping on Multilink1
It appears the router thinks the original priority percentages are still there and refuses to allow me to add the new ones.
Denny
Edison Ortiz
When making changes on the policy-map, it's recommend to remove the service-policy on the interface - make the changes in the policy-map and then re-apply the service-policy on the interface.
HTH,
__
Edison.
Hi Edison,
Thank you for your reply.
I was finally able to get it to apply, but I have no clue what I did.
I tweaked the percentages some more and when I went to apply the service-policy to the interface, the router said I needed to remove Fair Queuing from the interface first. I looked and was surprised to see it there.
I removed it them tried applying my service policy and it accepted it.
I will make sure I remove the service policy from the interface before adjusting my policy maps.
Thank you,
Denny
