QoS NBAR Issues
Joe Lee
Hi Everyone,
I have few questions about the NBAR.
1. Can the statement "match protocol http url "*abc.com*" pickup any https for url match?
2. I have already had the statement " ip nbar port-map customer-01 tcp 3222" (the tcp port 3222 is the proxy server port), I tried to apply "ip nbar port-map http tcp 3222", but it didn't take it. any reasons why?
Joe
To answer your questions:
1- No, it is supposed to check only requests on port 80, what you are talking about is secure-http responsibility
2- The command "ip nbar port-map http tcp 3222" should work, not sure why you are getting error, unless you have that port using for something else.
Hope it helps!
Network Group
