QoS on 1841 (limited throughput for class class-default)
ogencheva
Hello everyone,
I have an 1841 router with two T1 WICs. PPP is configured for Multilink1 interface and both serial lines are members of that Mu1 group. The following policy map is applied to Mu1 interface.
policy-map Small-WAN-PM
class IP-Voice-CM
priority percent 18
class IP-Video-CM
bandwidth percent 15
class Bulk-CM
set dscp af11
bandwidth percent 2
class class-default
bandwidth percent 40
Test 1
Transfer (push) FTP file (class-default class.) over Mu1 interface. No congestion on the line. The transfer hits max throughput about 1300kbps.
Test 2
Policy is removed form Mu 1 interface, no congestion on the line. FTP file transfer is repeated. Max throughput goes almost to 3000kbps now.
Test 3
Policy is modified as following and applied to Mu1 interface, no congestion on the line. FTP file transfer is repeated. Max throughput goes almost to 3000kbps now.
Above results are reproducible.
Background info - the other side of the link is terminated on 7200VXR router and use the same policy, transfer (pull) rate goes to 3000kbps in this direction.
It looks like a bug, but I could not find anything that will fit the description. Any suggestions?
11 Replies 11
Joseph W. Doherty
What's the Test 3 modification?
What's a show policy interface look like for tests 1 and 3?
Sorry, forgot to paste the last policy. It is basically the same deal, just removed bandwidth statement under class-default class and added fair-queue (see below) statement. Fair-queue statement did not make any difference. I tried it with and without that statement with same result.
class IP-Voice-CM
priority percent 18
class IP-Video-CM
class Bulk-CM
set dscp af11
bandwidth percent 2
class class-default
fair-queue
Below is output for sh policy-map on test 3. I can not get output for test 1 right now as it is a production router. I did not see anything out of ordinary on it though. Bandwidth was calculated correctly, there were a couple of drops on class-default.
CLNCL-1841-WR1#sh policy-map int mu1
Multilink1
Service-policy output: Small-WAN-PM
Class-map: IP-Voice-CM (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: dscp ef (46)
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 18 (%)
Bandwidth 540 (kbps) Burst 13500 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: IP-Video-CM (match-all)
0 packets, 0 bytes
Match: dscp af31 (26)
Queueing
Output Queue: Conversation 265
Bandwidth 15 (%)
Bandwidth 450 (kbps)Max Threshold 64 (packets)
(depth/total drops/no-buffer drops) 0/0/0
Class-map: Bulk-CM (match-any)
685958 packets, 84318057 bytes
5 minute offered rate 14000 bps, drop rate 0 bps
Match: access-group name BackUp-Traffic
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name SMS-Traffic
5 minute rate 14000 bps
QoS Set
dscp af11
Packets marked 685958
Queueing
Output Queue: Conversation 266
Bandwidth 2 (%)
Bandwidth 60 (kbps)Max Threshold 64 (packets)
(pkts matched/bytes matched) 26925/11383246
Class-map: class-default (match-any)
17947413 packets, 3930936868 bytes
5 minute offered rate 343000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/305/0
Test 1's class-default was FIFO and Test 3' class-default was FQ, then? In your original post you note 1.3 Mbps for Test 1 and 3 Mbps for Test 3, but in your reply post, FQ didn't make a difference and same result?
In your policy stats, Test 3(?), I see 305 recorded drops. Any of these happening during the FTP push test? What about for Test 1?
Test1 policy-map -
class IP-Voice-CM
priority percent 18
class IP-Video-CM
class Bulk-CM
set dscp af11
bandwidth percent 2
class class-default
Test3 policy-map -
class IP-Voice-CM
priority percent 18
class IP-Video-CM
class Bulk-CM
set dscp af11
bandwidth percent 2
class class-default
fair-queue
In test 3 also tried to remove fair-queue statement. With or without fair-queue statement the reslut is the same - around 3mbps theoughput.
with fair-queue statement Multilink int shows Queueing strategy: Class-based queueing,
without fair-queue statement Multilink int shows Queueing strategy: weighted fair
Regarding Test #3, with and without an explicit FQ statement, although display is a bit different believe it's, more or less, still FQ. Test #1, however, with an explicit bandwidth statement uses FIFO. I.e., queuing for class-default would be different.
It's possible the performance difference is due to different queue depths provided by FQ vs. FIFO. You haven't posted enough stats to know for sure, but if one implementation seems to register more drops than the other, if it does, a different drop rate could account for the performance difference.
What outputs would you like to see? Drops count is not consistant. It is always low though.
Show policy stats at the end of each test. This also assumes, counters cleared before test and no other traffic during test.
If drop counts not consistant, is there other traffic during test?
There is other traffic on the link. I did my testing during daytime. Though, no drops on physical interface or multilink at that time. It doesn't make any sense. Why would there be any drops (total drops)on class-default if there is no congestion.
I will repeat tests tonight.
I also hooked up two 1841( with 2 T1 WICs each) back to back with T1 x-over cables to see if I can reproduce this slowness and was not able to.
Why drops?
Individual TCP flows will "window" a set of packets at sender's interface speed. Insufficient sized router queues will drop packets if "window" larger than queue can contain. Packets drops will have TCP backoff its transmission rate.
Do I undersand correctly that you are suggesting that these drops will register only on sh policy-map int mult1 output, but not on physical interface (sh int)?
No, not suggesting that. I was just suggesting, TCP flow rates are impacted by drops. However, on the question of drops being registered on policy stats but not on the interface stats, believe they should show on both sets of stats. I don't have a ready explanation if they don't.
