ISDN down but there are open channels
Wassim Aouadi
Level 4
Level 4
It seemed strange. I have a Leased line as primary interface and ISDN as backup.
When primary link goes down, ISDN goes up. that's fine.
But when primary link goes up, ISDN is still up. And even if I shut down PRI interface AND dialer interfaces, router show me one open circuit in "show isdn active". I don't get it. How's that? physical interface is down and yet there's an open ISDN circuit?
my IOS version is 12.4(22)T
Forum Tips: 1. Paste images inline - don't attach. 2. If you find my post helpful, please give it a thumbs up or mark it as a correct solution; You never know in the future who you might help doing so..
slmansfield
Level 4
Level 4
Did you shutdown the controller or the serial interface associated with the D channel?
yes I shut it down, along with the dialer interface. But still I have ISDN circuit up in "show isdn active" !
The command you are using displays any active calls, as opposed to active circuits.
The middle of the attached document illustrates that layer 2 goes down when you shutdown the T1 controller.
I don't know why it would still show an active call over the PRI.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00801509d7.shtml
chinkevi_2
sound strange. Can you post your relevent config and output for everyone to see?
also sh isdn status before and after shut.
