Qos On 3750
mayank.parekh
Dear Member,
We want to configure bandwidth mangement on 3750 . there are number of vlans on 3750.
Can it possible by QOS ?
pls suggest
Jon Marshall
mayank.parekh wrote:
Dear Member,
pls suggest
Yes it's possible, the 3750 supports many of the QOS features. See the configuration doc for full details and configuration examples -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/configuration/guide/swqos.html
Jon
Thanks Jon,
If you have any example config then please share .
Thanks Jon,
Well it depends on what you actually want to do ?
If you search the NetPro forums with the specifics of what you want to do then there will be multiple answers that will provide config examples.
Jon
Please check we have just configure qos on 3750 for testing purpose
Is this write or we want to add som more ?
Switch(config)# ip access-list extended qostest
Switch(config-ext-nacl)#permit ip 172.16.25.252 0.0.0.3 any
Switch(config)# class-map qos-test
Switch(config-cmap)# match access-group name qostest
Switch(config-cmap)# exit
Switch(config)# policy-map test1
Switch(config-pmap)# class qos-test
Switch(config-pmap-c)# trust dscp
Switch(config-pmap-c)# police 10000 8000 exceed-action policed-dscp-transmit
Switch(config-pmap-c)# exit
Switch(config-pmap)# exit
Switch(config)# interface gigabitethernet2/0/1
Switch(config-if)# service-policy input test1
