QoS on 3750X
Dear all,
today I configured the folowwing QoS config. It seems to work, OR do you have any comments...I want to limit the Exchange traffic comming from the DataCenter to the location to 10Mbit (Download of big OST Files due to the Exchange migration).
class-map match-all LIMIT_EXCHANGE
match access-group 100
policy-map LIMIT_EXCHANGE
class CIFS
  police 10000000 1000000 exceed-action drop
interface gig X/0/XX
Provider_Router
service-policy input LIMIT_EXCHANGE
access-list 100 permit ip host Exchange-IP1 any
access-list 100 permit ip host Exchange-IP2 any
access-list 100 permit ip host Exchange-IP3 any
regards,
Sebastian
6 Replies 6
mgalazka
Sebastian,
Thanks for posting a nice short write-up on a problem and solution, it may help others in the future. I do have a couple comments:
1. The class name in your policy-map does not match the class-map you defined above. From your post, it appears the policy-map should have nested "class LIMIT_EXCHANGE" instead of "class CIFS".
2. You may find that using "shape average" instead of "police" gives better overall throughput.
Thanks for sharing!
Matt
Thanks for your reply..The naming problem, is already solved, sorry..
I will check out the shape option, thank you!
regards,
Sebastian
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
The 3750X doesn't allow generic traffic shaping.  However, if you can map this traffic to a specific egress queue, you can shape the queue.
Perhaps better yet, if you can map this traffic to a specific egress queue, you can allocate it a bandwidth proportion.  Done correctly, this traffic would be only given a set bandwidth proportion (such as your 10 Mbps) when there's contention for the bandwidth, but it could use more if it was otherwise not being used.
Ah, thanks JosephDoherty. I forgot, 3750X uses the "SRR" style QoS configuration. Agreed with your latter point as well, glad you added your comments!
Matt
thanks all,
Joseph, do you have an example for the engress queue config?
Disclaimer
Posting
I might, it depends on what exactly you want an example of.
Egress queues (4) are enabled when you enable QoS on a 3750X.
They start with a default configuration, to which there's quite a few commands and parameters to change, if you chose to do so.  This is different from a software router's QoS where you usually start with a single FIFO and they you define how QoS will be configured.
Many of the commands are global, i.e. they will impact all the interfaces.  Again much different from a router's per interface QoS configuration.
For you case, you would need an ingress policy to classify and mark traffic, global commands to define how markings get mapped to the built-in egress queues, perhaps global buffer and WTD settings and finally egress queue bandwidth ratios for a particular interface.
