QOS on SIP-400
anasubra_2
Hi All,
We are trying to deploy the below configuration on a POS interface on SIP-400 module(7606) running the IOS image (s72033-ipservicesk9_wan-mz.122-33.SRA1.bin).
The configuration template is as below
class-map match-any <ACL1>
match access-group name <ACL1>
class-map match-any <ACL2>
match access-group name <ACL2>
policy-map <NAME>
class <ACL1>
police 1000000 conform-action transmit exceed-action drop
class <ACL2>
ip access-list extended <ACL2>
permit icmp any any echo
ip access-list extended <ACL1>
permit icmp any host <ip-address> echo
interface POS3/0/0
service-policy input <Policy Name>
By the above config , the show policy-map interface pos3/0/0 doesn't show any matching or even matches in the default-class. We are not sure, what would be the reason. Kindly let us know, if we have missed something on that. I hope matching the ICMP protocol under the named ACL shouldn't be an issue. MLS QOS is been enabled.
Any help is appreciated.
Thanking You
Anantha Subramanian Natarajan
Pavel Bykov
Level 5
Level 5
You are saying that there are no matches even in class-default?
I assume you checked the traffic counters on interface POS3/0/0, and there is input traffic?
It would seem then that the map is not applied on the correct interface level. I'd create a test map with only class-default and try applying it on interfaces that might relate.
Then check with show policy-map command where the counters are increasing.
I haven't had the chance to configure 7606, so can't help you exactly. But i did many QoS policies on POS interfaces without any trouble.
