QoS/packet filter appliance
dbellaze
Level 4
Level 4
Can some one recommend an internet facing device that could provide the following.
Qos and deep packet inspection filtering.
I'm not looking for a firewall piece of equipment just a dedicated appliance that internet traffic flows through that is specifically made for this type of thing.
Some thing that works transparently would be best as I don't want any routing intelligence on the device.
Daniel
leonvd79
Level 4
Level 4
Take a look at the products from Allot Communications.
http://www.allot.com/html/products_netenforcer.shtm
Leon
* Please rate posts if you find them helpful.
