QoS policy fail on vlan interface of a router 3845
ashley_dew
I have configured a qos policy and I am trying to apply the policy to a vlan interface which is physically connected to a switch module port of a 3845 Router.
When I try to apply, the message configuration failed appears.
Here is the policy map
class-map match-any VPN
match access-group name VPN_Spidernet
policy-map child-VPN-Spidernet
class VPN
bandwidth 128000
shape average 256000
class class-default
fair-queue
  random-detect
policy-map parent-VPN-Spidernet
class class-default
shape average 1000000
service-policy child-VPN-Spidernet
ip access-list extended VPN_Spidernet
remark VPN sortante tunnel seulement
permit ah any any
permit esp any any
Here's the configuration of the interfaces
interface Vlan2
description connexion Internet Spidernet
bandwidth 1000
ip address x.y.z.189 255.255.255.128
ip access-group CONNEXION-ENTRANTE-SPIDERNET in
ip nat outside
ip inspect Firewall out
ip virtual-reassembly
interface FastEthernet0/0/1
description Connexion Internet Spidernet
switchport access vlan 2
bandwidth 1000
duplex half
speed 10
When I do in config mode
int vlan 2
service-policy output parent-VPN-Spidernet
I have got the message Configuration Failed !
Could you please help.
Ashley
matt.eason
Hi Ashley,
QoS functionality on an etherswitch module is limited and doesn't offer the same level of features that would usually be available.
Unlike a standard Fast/GigEthernet port on a router the etherswitch modules are not capable of doing red, shaping, cbwfq etc..  According to Cisco's documentation you are limited to class based marking, policing on 15.1(1)T and car(another form of policing)
You should still be able to implement some form of bandwidth reservation by using the etherswitch modules WRR queuing system.
These websites have further information should assist you.
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/prod_white_paper0900aecd8064c9f4.html
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_qanda_item09186a00802c9e7a.shtml#qa28
Matt
Marwan ALshawi
Hi Ashley
i dont thin you can apply if to the vlan interface i mean outbound shaping policy map
some cisco switches they do support some policing with the use of per vlan QoS
but for this ISR switch module  i am not 100% sure but almost it is not gonna work
i recommend you to use the actual physical interface rather than the vlan interface
by the way why you have the depulx hardcoded to half ? this not related to QoS but better to have full either auto or hard coded depending on the other end setup !!
Thanks for the update. You are probably right for the QoS. I will try on the physical interface directly or try to use CAR on the SVI.
I know the hardcoded duplex is strange. Its the Wimax modem connected on the interface cannot negociate with the router and cannot run on 100 Full. The only working config is 10 Half. We are waiting for the ISP to change their modem or cable.
Again thx for the update.
Ashley
matt.eason
Hi Ashley,
Matt
Hi Matt,
I will try to use CAR on the SVI but first I will need to upgrade the router to 15.1(1) T. Currently it is on 15.0.
Thanks for the excellent references which is in the right direction.
Ashley
