QoS policy-map (set dscp) on catalyst 3850 (MLS QoS) mot working
CSI:Net
I'd like to set to all ip traffic on input port (Calayst 3850, 03.07.05E)  to DSCP=0.
But I doesn't work, I'm sure because on destination I still see dscp = other than 0.
Is there any limitation on 3850 input policy.map config ?
here the config I did:
policy-map untrust-port
 class class-default
 set dscp default
interface TenGigabitEthernet1/0/1
service-policy input untrust-port
do you see any marked packets when you issue the command:
show poliy-map interface TenGigabitEthernet1/0/1
