TFTP via VRF
chopra.nitin
I have to download IOS into my 10K cisco router.  The problem is I am getting the TFTP server route from VRF table and not global routing table.  Is there any way I can download from VRF table?
The current ios command is copy tftp<> flash<>
Thanks for your reply
20 Replies 20
sachinraja
Level 9
Level 9
Hi Nitin
Is it possible for you to leak the route from VRF to the global IP routing table  or vice versa ? once your vrf route leaks to global, your router will be able to see the tftp server on normal ip routing table. Im not sure about your internal setup or complications, but you can probably have a look at this doc for more help:
http://www.cisco.com/en/US/tech/tk436/tk832/technologies_configuration_example09186a0080231a3e.shtml
Hope this helps..  all the best..
Raj
Ik think you can solve your problem to set your tftp source interface to one into the correct vrf
try "ip tftp source interface X"  where X is member of the vrf
You are correct Sir.  That worked like a charm for me.  Thanks... Cheers!!
Thanks man you save my life...
this just worked for me. Thanks
Thanks Caiw... Your answer solved my problem
sorry to resurrect an old thread, but thanks.  Saved my bacon for a VSS ios upgrade.
awsome!!
I am upgrading the code on SUP6T, and had he same issue, glad that I came across this discussion. Thanks "caiw netwerkbeheer"
Yes, this 7 year old post helped me too!!!
Saved me a lot of time, thank you!
Concise and helpful... Thanks
Works fine with "ip tftp source-interface BDI501 " in my ASR920 Router
Interface BDI501 is in a vrf.
Thanks !
This worked for me also.  Thanks.
