QoS Policy on GRE tunnel not activating
mhattar
Hi all,
Just wondering if someone ran into a similar issue like mine , I tried configuring a policy on a GRE tunnel in the outbound direction , it takes it into the config no problem , then you add the bandwidth statement on the interface , you get the message that the policy is activated ,  you do a "show policy-map int tu 0" , and its still showing in suspended mode.
s207-81-129-56(config-if)#do show policy-map int tu 0
Tunnel0
  Service-policy output: POLICYIN
    Service policy POLICYIN is in suspended mode
here are the relevant lines of config:
class-map match-any POLICYIN
match access-group name POLICYIN
policy-map POLICYIN
class POLICYIN
  priority percent 40
class class-default
  queue-limit 8 packets
  random-detect
-also tried a nested parent policy with shaping average feature , instead of a single policy with a bandwidth statement on the interface.
-tried bandwidth qos-reference statement on the interface
- tried qos-preclassify with no use either
- also tried applying policy (both the shaping /nested policy) or the bandwidth statement with a single policy on the underlying interface loopback 0
14 Replies 14
Hello
Is this tunnel part of a etherchannel?
Also on the tunnel interface have you applied?
int tun xx
qos pre-classify
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
mhattar
Hi Pdiver,
I have tried that (As indicated in the description )
thanks,
Hello
Apologies I didnt see that.
Thanks.
Kind Regards
Paul
Rodrigo Pires
Hi Murad,
As fas as i know, when the allocated bandwidth exceeds the amount of available on the traffic policy remains suspended.
Have you tried to modify the traffic policy?
Also, i found this from cisco website "
For instance, if a traffic policy is attached to a tunnel interface  while another traffic policy is attached to a physical interface--with  which the tunnel interface is associated--only the traffic policy on the  tunnel interface works properly."
Here is the document:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_mqc/configuration/12-4t/qos-mqc-12-4t-book/qos-mqc.html
[]s
Please rate
thiagohubes
Murad,
Try this:
policy-map PARENT
     class class-default
          service-policy POLICYIN
          shap average percent XX
interface tunnel0
     service-policy output PARENT
mhattar
Hi Thiago and Rodrigo,
interface Tunnel0
bandwidth 5800
ip vrf forwarding outside
ip address 10.3.3.3 255.255.255.0
ip nat inside
ip inspect INSPECTION in
ip virtual-reassembly in
tunnel source Loopback0
tunnel destination 10.1.3.4
service-policy output POLICYINPARENT
s207-81-129-56#show policy-map POLICYINPARENT
  Policy Map POLICYINPARENT
    Class class-default
      Average Rate Traffic Shaping
      cir 5000000 (bps)
  Policy Map POLICYIN
    Class POLICYIN
      priority 2000 (kbps)
    Class class-default
       wred, exponential weight 9
... So basically tried to place a parent policy so I would be able to trigger a congestion state..but that didn't help , it kept telling me the policy is in suspended mode. Thanks you all for your efforts though!
Cheers,
Vishesh Verma
Hi Murad,
What is the platform & IOS?
what is the interface through which this tunnel is going out?
show ip cef 10.1.3.4
Provide the configuration of the interface which comes in the ouput of command above.
-Vishesh
Hi vishesh,
It's an 891 running C890-UNIVERSALK9-M), Version 15.2(4)M4.
#  show ip cef 10.1.3.4
10.1.3.4/32
  receive for Loopback1
show run int lo1
Building configuration...
Current configuration : 64 bytes
interface Loopback1
ip address 10.1.3.4 255.255.255.255
end
#show int lo1
Loopback1 is up, line protocol is up
  Hardware is Loopback
  Internet address is 10.1.3.4/32
  MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     15 packets output, 855 bytes, 0 underruns
     0 unknown protocol drops
cheers,
Hello
What is the tunnel built upon - are the physical interfaces aggregated?
Are the source/destination addresses of the tunnel reachable to each other?
Res
Paul
Kind Regards
Paul
Hi Paul ,
the tunnel is sourced from a loopback interface on a VRF instance  no aggregation of any sort.
interface Tunnel0
bandwidth 5800
ip nat inside
the tunnel endpoints should be able to talk to each other I suppose as I am getting an internet feed though the tunnel . both endpoints are in UP/UP state.
Murad
Hello
The tunnel will be up anyway as you have no keepsalives specified
Do you have reachability between source and destination addresses of the tunnel with/without the qos policy applied
Res
Paul
Kind Regards
Paul
Hi Murad,
This is not making any sense to me. Tunnel is sourced from this router from loopback0 and is destined to loopback1 of the same router? Or is it that 10.1.3.4 is also a remote router which is routable through the VRF?
interface Tunnel0
interface Loopback1
end
Also, note that egress QoS features on 800 series router is supported only on the WAN links ATM, Routed Gigabit port. If the tunnel is going out of a physical interface which is part of Etherswitch Module(Vlan) QoS would be in suspended mode.
-Vishesh
Hello Vishesh,
This is exactly why I have it setup like that , its because it's an 800 series router and I would like to apply Qos in the inbound direction. We know that the WAN interface only supports QoS in the outbound so I found the solution by creating a VRF and called it outside . created a tunnel interface between this VRF and the "global router" so that I can apply the policy on the tunnel interface 0  in the outbound direction , essentially being able to apply QoS in the inbound direction. I didn't mention these details in the initial description of the problem because I didn't want to overcomplicate it and incl. the details that are relevant to my problem.
The solution is found on this document on page 47 :
stor.balios.net/Live2012/BRKRST-3500.pdf
router#show ip int br | e una
Interface                  IP-Address              OK? Method Status                Protocol
FastEthernet8              207.45.45.56   YES  DHCP   up                    up
Loopback0                  10.1.3.3              YES manual up                    up
Loopback1                  10.1.3.4              YES manual up                    up
NVI0                       207.45.45.56          YES  unset  up                    up
Tunnel0                    10.3.3.3                 YES  manual up                    up
Tunnel1                    10.3.3.4                  YES manual up                    up
Vlan1                      192.168.110.251   YES  manual up                    up
#show ip vrf outside
  Name                             Default RD          Interfaces
  outside                          1:1                 Tu0
                                                       Fa8
Also ping to 4.2.2.2 works as well when sourced from vlan 1 which means the packets are traversing the tunnel between global and outside VRF just fine .
#ping 4.2.2.2 source vl 1
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Packet sent with a source address of 192.168.110.251
Success rate is 100 p
Hope it makes sense now,
Cheers,
Hi Murad,
It is kind of a Hack, and it is awesome. But as per BRKRST-3500.pdf it worked prior to HQF. Your router runs 15.2(4)M4, which implements HQF.
If you want to imlement it you have to downgrade the IOS code to some prior to 12.4(20)T. As HQF was introduced in this IOS code.
-Vishesh
