08-03-2015 07:49 AM - edited 03-05-2019 01:59 AM
Ok looking at this policy: Beside all the voice protocols that I am defining in the first class map, I want the rest of the traffic no matter what it is to fall into the default class map. So does this work?
class-map match-any MPLS_VOICE_CHILD
match protocol rtp
match protocol rtsp
match protocol sip
match protocol skinny
match protocol h323
match ip dscp ef !
policy-map MPLS_QUEUEING_CHILD
class MPLS_VOICE_CHILD
priority percent 25
set ip dscp ef
class class-default
policy-map MPLS_POLICYMAP_PARENT
class class-default
shape average 50000000
set ip dscp default
service-policy MPLS_QUEUEING_CHILD
interface FastEthernet0/0.3086
description **
bandwidth 50000
encapsulation dot1Q 3086
ip vrf forwarding mpls
ip address x.x.x.x 255.255.255.252
service-policy output MPLS_POLICYMAP_PARENT
Will this allow all traffic that isnt marked for voice protocols to fall into the default class and be set as dscp 0? And will it use the rest of the 100 percent of the pipe (which is 74 percent) for that class of traffic (DSCP 0)?
08-03-2015 09:26 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
"Will this allow all traffic that isnt marked for voice protocols to fall into the default class and be set as dscp 0"
Not as I suspect you intend. See revision policy-maps, below:
priority percent 25
set ip dscp ef
class class-default
set ip dscp default
class class-default
set ip dscp default
"And will it use the rest of the 100 percent of the pipe (which is 74 percent) for that class of traffic (DSCP 0)?"
Class-default, as configured in child, can use 100% of the parent's bandwidth.
BTW, on most platforms, your MPLS_VOICE_CHILD will only be limited to 25% if there's queuing.
08-03-2015 10:30 AM
But I want to make sure there is always bandwidth for voice? Am I not queuing with the "Priority" command?
08-03-2015 12:17 PM
Disclaimer
Posting
Yes, your policy guarantees bandwidth for voice, in fact, 25%. On some platforms, voice might even use more.
However, unused voice bandwidth is available to other traffic, up to 100% with your policy.
08-03-2015 12:20 PM
So there is no way to say that even if voice isnt using 25% of the pipe, only allow all other traffic to use 74 percent regardless?
Also is there an "order of operation/processing" when it comes to the QoS policy? Is the class default evaluated last?
So if I was to put in a match any on the class default would the voice traffic get marked before the class default was looked at?
08-03-2015 04:32 PM
Disclaimer
Posting
"So there is no way to say that even if voice isnt using 25% of the pipe, only allow all other traffic to use 74 percent regardless?"
No, not saying that. You might be able to police or shape class-default too.
"Also is there an "order of operation/processing" when it comes to the QoS policy? Is the class default evaluated last?"
Yes, top to bottom, with class-default always at bottom (regardless how you enter it).
"So if I was to put in a match any on the class default would the voice traffic get marked before the class default was looked at?"
Class-default is already an implicit match any (not otherwise matched). Other classes, tht match traffic, will process that matched traffic.
08-04-2015 05:54 AM
Ok so as long as I am setting other classes to match certain traffic, that said traffic will never hit class default. class default is like the clean up bucket. "Anything that every other class map doesn't match I will catch it and mark it as dscp 0.
So I am kind of looking at QoS policys like programming in a way...you define your variables (class maps), then you set them in the policy which is kind of like a sub routine. But I can see that it could very complex depending on how much you nest.
08-04-2015 09:33 AM
Disclaimer
Posting
Yep, class-default is like a "clean up", or, none of the above.
There's always a class-default. If you don't explicitly define it, there will be one implicitly.
